Question about Toshiba 43H70 43" Rear Projection Television
62inch phillips bigscreen tv
Have a problem trying to get the tv to turn on, sometimes it does, sometimes it doesn't.
the power button will blink off and on also
  • Toshiba Master
  • 8,617 Answers
How many times does the power light blink, that can be an error code indicating whats causeing the set to not start. Let me know how many blinks its blinking and also let me know your model number.
Posted on Apr 26, 2008
My 60 inch phillips tv, I turned it off the other night and now all i get when i turn it on is the power button flashing green. 6 quick flashes and then 1. I need my tv, plz help
Try a new Web search for your brand. Try looking for a Diagnostic trouble code of 6-1 and see if you can pull up parts of a Service manual using that search routine. Try Phillips trouble codes, Phillips Diagnostic Codes, or your model# in the search.
It sounds like it went into a default Diagnostic mode. If you have a Remote with extra functions it may get you into the Diagnostic menu.
Dec 20, 2011 | Televison & Video
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
60'' Mitsubishi bigscreen will not power up
this could be a lamp our a ballast issue
regards
Dec 12, 2009 | Televison & Video
Power went off in house when it came back on the green light on the front panel keeps blinking will not stop Mitsubishi Bigscreen model ws- 65909
I've got a 65535. When this happens, you can sometimes press the On-Off button for 10-15 secs until the light goes off. If that doesn't work, then unplug the tv for 30 seconds or so, then plug back in.
These sets are known to have power supply issues, and the blinking light may be a coincidence to the power supply failure. It's fairly easy to repair if you know how to solder.
Dec 10, 2009 | Televison & Video
I have bigscreen phillips tv and sometimes the volume goes in and out and now the volume and menu dont show up at all on teh screen when pushed on the remote
You have a bad signal board. To be sure this is correct...unplug your tv for several days or even a week or so. The tv will work fine for a few minutes and act up again. A very common problem for this brand. These are pricey and will need a complete geometry setting by a tech.
Aug 16, 2009 | Televison & Video
My RCA Bigscreen HDTV will not turn on.
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
Code for p1300ntv to work with directv remote
You can "manually" find your code by  1. pressing tv button on the remote 2. press and hold setup until TV button blinks twice 3. press 991, the tv button should blink once 4. slowly press and alternate the power and tv buttons until tv turns off.   5. press setup to lock in the code when tv turns off.
hope this helps,  j
Jan 14, 2009 | Disney 13" TV
My phillip 51 inch will not turn
this happened to me once i think the problem is that the button is used so infrequently that it sticks try pushing it very hard as many times as needed and id and when it comes back on dont use the button anymore just stick to the remote
Feb 14, 2008 | Philips 51PW9303 51" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
