Question about Gaggia Platinum Vogue 90800 Espresso Machine
Gaggia coffee maker will not turn on.
I think someone plugged too many appliances in and it could not draw enough power. Now it won't turn on at all.
  • cmulley Sep 04, 2009
    It is less than a year old, so nothing should have "burned out" yet. Looking at the picture that was posted, it is not exactly that coffee maker - mine has a touchscreen LCD display. That has shown some small signs of life at times, but only very briefly. That was why I was thinking maybe it was a "computer problem" - a bit like when a car's on-board computer stuffs up if you try to push-start a modern manual car.
  • 34 Answers
Your problem can be solved by only two choices.
One is to let the experts do it for you by bringing it to a specialist.
and second is to replace your coffee maker.
Hope this link can help you find a new one.
http://www.coffeemakerwizard.com/
Posted on Feb 03, 2010
  • 797 Answers
I had a similar problem with a friend's coffee maker. May not be the same kind.
Does any of the led lights come on at all or the read-out lcd light up? If they do, then more than likely it is the heating element.
These coffee makers have a limited life. the element usually is the culprit to go bad first. They are in cold water and have to heat the water to boiling steam to get the coffee to brew correctly.
Another thing is to repair these is usually not worth the time and effort.
If you have a commercial coffee maker, that is a different case, and maybe should be looked at by a repair man or replace the parts broken.
Posted on Sep 04, 2009
Why does my baby gaggia have good steam but no flow for espresso?
turn on as if to make a coffee and then the stemer. Some time it's to do with drawing the water from the tank. Otherwise I'd descale it, that will defo fix it.
Nov 18, 2014 | Gaggia Baby Espresso Machine
My new accademia gaggia won't work, error code 05
see this causes and fix it. God bless you
Reset the code read your instr. manual
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord, the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 1003380 Accademia Espresso Machine
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
My new gaggia accademia won't work. It shows error code 19. Can you help me?
Hi, Error 19 is not known by me. Sounds like something is not resetting or has failed. Try turning off the machine at the main power switch and unplug it from the wall for a few minuites. Remove the dreggs draw and drain tray and replace them before you plug it back in. This will allow the machine to reset. Dazza REPAIRER
Sep 24, 2011 | Gaggia Coffee Makers & Espresso Machines
Hi i have a gaggia classic there is steam coming but not
Check out this diagram it will give you a start on the machine. I think the problem is the valve above the 2 diffuser screws behind the shower screen.
Aug 20, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Doesn't power up
Same problem here, working one minute, lights out the next. No signs of life. Hoping there is a fuse or breaker somewhere.
May 12, 2008 | Gaggia Syncrony Compact Coffee...
Coffee not strong enough
our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Feb 09, 2008 | Gaggia Titanium Espresso Machine
Machine Does not draw water into the boiler
I have had this same problem - it is due to an airlock in the boiler/tubes. Simple solution is to use a syringe or similar and gently force some water up the intake hose from the tank, then try the pump again.
May 21, 2007 | Gaggia Evolution Espresso Machine
Gaggia Platinum Vogue 90800 Espresso Machine Logo
161 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
