Question about RCA Universal Remote Control
My tv stopped responding to the remote for some odd reason ( the remote seems fine ) how do i reset it ??
  • 147 Answers
The problem is the IR Receiver in the tv needs
replacing,this is the receiver thay receives the
signal from the remote.there is no reset for
this type of problem.Also you my try new batteries in the remote and a new remote if the
IR Receiver does not repair the problem.
Posted on Sep 04, 2009
Is there a microprocessor/software reset procedure?
Simply disconnecting power for a period of time should reset it. I would do so over night.
Aug 15, 2016 | Symphonic Televison & Video
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Hi there, I've just moved into a new apartment and the Samsung Timesaver microwave seemed to be working fine yesterday, but it has been beeping at odd times for no reason. I turned the power off to stop...
Hi, this is usually a bad touchpad. The way to tell for sure is to kill power to the unit, take the control panel down and unplug the ribbon connector that connects touchpanel to the clock. Put it back together and reapply power. The clock will just sit there blinking and, obviously, the buttons won't work, either. if the beeping stops, then the touch panel is bad. And If it still beeps, then you have a bad clock.
Apr 03, 2011 | Samsung MC5694 Microwave Oven
Remote doesn't work.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try the following: use an air-can and dust the multiple component input/output slots everywhere on the TV itself. If this doesn't solve the problem, connect standard 1/8" headphones into the remote control OR the headphones jack on the TV. Then unplug the TV for a minute. Plug it back in, turn it on, and see what happens. Hope this helps,...it may not seem relevant, but it works for some reason.
Good luck...
May 23, 2010 | LG 37LG30 37 in. LCD HDTV
Original TV remote has stopped working
I HAVE HAD THE REMOTE RECIEVER INSIDE THE TV BAD IN THE PAST-ITS RATHER INEXPENSIVE AND ONLY HAS 3 LEGS TO UNSOLDER TO REPLACE IT
Sep 04, 2009 | Televison & Video
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Remote works intermittently
Hi!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:first try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com.
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Oct 09, 2008 | Kenwood VR-407 Receiver
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Menu not working.........
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Panasonic TC-26LX60 26 in. LCD Television
Televison & Video Logo
311 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
