Question about Acer Aspire 5670 Notebook
Removing Acer Acpire 5670 keyboard to replace cd/dvd burner
Sorry dont have that part to pull up,is there anything between the two hinges on the right hand side [i have three hinges in all] thanks for your time and help
    President:
  • 2,600 Answers
Try this: it is the service guide for your model. Good luck, ParrotHead PC Repair
copy and paste to the browser address bar, hit enter....
http://tim.id.au/laptops/acer/travelmate%204210%204270%204670%20aspire%205620%205670.pdf
Posted on Sep 04, 2009
Testimonial: "very helpful and detailed,cant fault the help given to me on this site.Will recommend to others.Thank you for all your time and help. "
How to take off keyboard laptop acer 5670 ?
Hi there !
It is easy remove the laptop keyboard for acer and here's how to remove the keyboard.
Use philip screw driver and pointed knife to remove the lock buttons located in both left side and right side, and top side of the keyboard. You have to start removing the lock from the top side and then in left and right side. Each lock button you unlock, you have to flip it not to return the lock. Gentle flip it up not to damage the ribbon connection at the back of the keyboard. Once you see the ribbon connector, release the lock and remove the ribbon connector. That it and it is finish. Do what ever you. If defective, replace it and if it dirty, clean it gentle.
I hope it helps you and Good Luck.
Jan 07, 2011 | Acer 9J.N5982.C5D - Aspire 5670 Series...
Replace laptop dvd burner
yes there should be some proble with DVD writer (hardware) there is no problem with your software drivers or applciation.
Please call your service center or coustomer care to repalce it if your laptop is under warrant!
Jan 11, 2010 | Acer Aspire 5670 Notebook
I have an Acer Aspire 5670 Note book Computer
There is a small hole on the face of the tray which is used to open the tray in this kind of situation. Use some needle and push into the hole. If the tray does not come out, you have to open the laptop and remove the tray.
Sep 20, 2009 | Computers & Internet
How do i remove acer aspire 5670 keyboard to replace cd/dvd unit
Hi there.
Push the screen back
Lift up the keyboard bezel using a small flat-head screwdriver.
Continue removing the bezel with your fingers.
Lift up and remove the keyboard bezel.
Remove two screws securing the keyboard.
Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Remove the keyboard.
Good luck and thanks for choosing FixYa!!
Sep 04, 2009 | Acer 9J.N5982.C5D - Aspire 5670 Series...
Need 4 replacement keys for acer acpire one 10.1
Replacement keys are usually specific to your model laptop/keyboard. If you are missing some plactic hinge components an the rubber hat contact, then you need to replace the keyboard.
There are companies on the Internet that supply replacement keyboards, Google search for replacement keyboards for your model laptop.
Jun 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
Wont Read OR Burn DVD's
Hi There that is a hardware failure inside the unit there are two different lasers in the one head one for cd and one for dvd it sound like the dv d head has failed if the unit is new or under warrenty its time to speak to your supplier or if not bite the bullet and invest in anew unit
sorry for the bad news
Regards AL "Alstech"
May 24, 2009 | Sony DRU-710A DVD±RW Dual Layer...
Acer Aspire 5670 problem
dont insall web cam software from the acer mother board cd
Jan 09, 2009 | Acer Computers & Internet
HP Compaq nx9010 CD drive replacement
You are correct.
The screws for the dvd drive is under the keyboard.
there should be 2 tabs one above the f4 and the other above f12 take a regular head screw driver put it where those tabs are and gently pull down towards the touchpad and the keyboard should come up easily.
Now under that keyboard in the center you will see a opening and inside that opening you will see 1 philip head screw remove that by turning counter clockwise.
Right below where you removed that screw you will see another opening which has another philps head screw in it.
Remove that screw counter clockwise and the dvd rom should pull straight out with ease.
To put it back together just reverse the steps.
If you need further assistance do not hesitate to ask.
Dec 03, 2008 | HP Compaq Business Notebook NX9010
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5670 Notebook Logo
625 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
