Question about Packard Bell 1580509280 Network Adapter
6T04 Adapter failure
My laptop Hp dv5000 can detect wireless signals but i cant open any web pages. The device manager shows that my 6T04 Adapter cannot start, how do i fix this?
    Brigadier General:
  • 4,044 Answers
That 6to4 adapter has been a problem for as long as I have been aware of it but I only have that issue when I use my print server. I don't believe the 6to4 is your actual wireless. Are you using a wireless print server?
Posted on Sep 04, 2009
Getting internet signal but cannot use internet
In the Tray Notification Area, the Network Icon, is it Xed out? Is it there? Open Device Manager, Network Adapters, is it enabled? Do a scan for Hardware changes in Device manager. Have you reboot the machine ?Has it connected before? Are you using Win XP? You can find the drivers for Broadcom WLAN, look for Drivers-Network, here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=435618
Dec 31, 2012 | HP Pavilion dv1000 Notebook
MY HP PAVILLION'S PORTS DON'T WORK, INTERNAL WIRELESS DOESN'T WORK AT ALL
Most of the laptops those are the common issues Wireless are not working, what i suggest is try to renistall the Driver for the wireless card then check it in the Device Manager, if it doesn't show in Device Manager the wireless card could be faulty.
How to check Device manager.
Start->Control Panel->Device Manager
Inside Device Manager look for Network Adapter and check if your wireless card is detected.
Apr 04, 2011 | HP Pavilion dv6000 Motherboard
I hava a hp 13" laptop that wont show wireless option in the internet properties. I have a wireless Lan Mini PCI card, but it is not being detected. Is there away to re enable the wireless?
Hi. Please check first if your computer was able to detect the device. You can look for this device in control panel then click system then click device manager. Your wireless adapter should be present under network adapters. f computer was able to detect the wireless adapter. Try to turn off/on the wireless switch. Usually, wireless switch is located infront of the laptop or on the side. You can also try pressing Fn + F5 key to disable/enable wireless network card.
Jun 13, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
Internet connecting problem
First remove the antivirus suites and firewalls. Open IE Go to Tools -> Internet Options -> Connections -> Lan Setup Check whether "USe proxy server..." check box is checked. If so untick it. Apply and Ok. Then check. If you are bot sure whether you have a proxy or not you can chose "Automatically detect settings". That will override manual configs how ever. Alternatively you can check Connection settings of Firefox since it is working.
Check the device manager for the adapter status. Right click on My computer and go to manage. If it has yellow exclamation marks or red X as you said that means a device failure or driver failure. If so you have to rollback the drivers and if it doesn't work uninstall and re install drivers. Use Add Remove programs if a software is there. If you use a software to configure / access the network appliance (if you have one like a wireless router) un install and re install it.
Check this thread as well.
This 6to4 adapter is a IPv6-to-IPv4 conversion layer. If you are not using IPv6 communications across IPv4 routers, you do not need 6to4 enabled. You can disable it. What is the IP address you are using? Is it ip v 4 or 6? Check using ipconfig using a command window (cmd.exe in run box and hit enter). Not necessary to use IPv6 (only if your college or etc etc use IPv6. Check this thread as well. isatap will not work on Vista but it doesn't do any harm though. :D
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem.If the problem persists please contact us. Thanks for contacting Fixya
May 28, 2010 | Acer Computers & Internet
Code 31 cannont load driver 6T04 adapter
To resolve this concern, first thing to do is to uninstall the device from device manager and then after that restart the computer and run the setup cd that came with it to reinstall the software and the device back to your computer....
Jul 29, 2009 | Packard Bell 1580509280 Network Adapter
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Gateway 8510gz laptop with no wirless
go to the manufacturer web site (download/support) and download the XP wireless driver for your laptop
Jun 29, 2009 | Gateway 8510GZ Notebook
Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
PLZ GIVE RATING BY CLICK ON YES or NO.
Mar 21, 2009 | HP Computers & Internet
NETWORK ADAPTER PROBLEMS FOR HP LAPTOP
go into device manager click on wireless device and update drivers or in device manager delete wireless device and restart.
on restart sysstem will detect and install found device(wireless)
you may have to reconfigure so check ip address,dns and gateway details first (find them by clicking on your wireless icon and select properties,scroll to internet protocol.select it get details.
Jan 10, 2009 | HP Pavilion dv6000z Notebook
Wireless connection disapeared from computer
Hello!
I am not sure exactly where you are checking for Wireless connections.
Anyhow, now a days we are hearing many Wireless adapter missing from Device manager issues.
Please get back to us with the Brand name of your laptop, OS installed.
Also check in Device manager for Wireless adapter.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Network adapter and check if the Wireless adapter is listed there or not.
If it is not listed there, then the issue is with the Wireless adapter itself.
This is most comon issue in HP COMPAQ notebooks.
if you are not aware of the Wireless adapter under + Network adapters in Device manager, then get back to us with the complete information under + Network adapter.
So thatI can help you in better way
Aug 09, 2008 | Computers & Internet
Packard Bell 1580509280 Network Adapter Logo
632 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
