Question about Dishwashers
It didn't drain > only 2 1/2 years old > and I clean my dishes good before loading etc... ?? Help
    Sergeant:
  • 222 Answers
Run CLR through it
check that the drain hose is clear, did you recently get a new disposal?
check routing of drain hose to disposal, do you have an air gap at the sink before the disposal? is it clear?
hard water deposits?
Posted on Sep 04, 2009
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
Dishwasher is 2 years old. Top shelf dishes not getting clean even on on heavy duty and sani rinse cycle. All arms move freely,tried the 2 cups white vinegar in an open container and run cycle. I thought...
Sometimes the holes in the arms get blocked up,sweetcorn,rice etc, this then stops the arm spinning and water being sprayed onto plates etc, unscrew it and run water through the centre hole and see what happens.
Oct 06, 2009 | KitchenAid Dishwashers
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishes have filmy finish
hello. this will help a great deal.
First of all empty out your dishwasher, toss in two cups of plain white or cider vinegar and run it on the highest and longest cycle.
Always run the hot water in the sink first and start the dishwasher only when the water is as hot as it will get.
This wash will clean out your dishwasher thoroughly.
Then always do your dishes after you have rinsed any residue off of them before placing them in the dishwasher and I always recommend the pot scrubber cycle if you have one.
Jul 07, 2009 | Dishwashers
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Top dishes don't come clean
Dear friend,
ngfam at you service! happy to assist!
Go into the user manual and read how to properly load your dishes to get the maximum cleaning potential!
there are certain ways to load the dishwasher that allows the spry to hit all the dishes.
Second check the bottom of the dishwasher if there are food particles left on the bottom at the end of the wash!
They can be the problem if they are recirculating back onto the dishes and then drying on them when the dry cycle goes on!
Third, They sell for about 5 to 8 dollars a small box of dishwasher
cleaner that you ad and run with no dishes in it 2 times a year!
And last, there may be a problem withe the drain or pump that its not pumping out all the wash water!
If this is the case you need service to check it out before some one in your family gets violently ill..!
We sell appliances for 65 years and I recommend this nation wide Factory repair service to all my retail customers!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dirty dishes
You need to take the spray arm off of the bottom and get down to the filter: there's probably food trapped in the filter somewhere, not able to drain out and it keeps recycling onto the dishes at each cycle. Good luck!
Jul 17, 2008 | Sears 24 in. 14181 Built-in Dishwasher
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
