Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
My frenchdoor fridge keeps running constantly. Doors are fully closed and the temp seems right (now!!) but the motor keeps going. what can I check? Please & Thank you!
    Sergeant:
  • 222 Answers
Does it run all night too?
the fridge will run as long as it needs to to obtain and maintain the selected temperature,
the freezer should be set to zero and the fridge to 38
Posted on Sep 04, 2009
Whirlpool Refridgerator Model # ET1FTKXKQ00 My Question: I can not seem to locate the hose that would take the moisture from the freezer/fridge to the evaporation tray at the bottom. My fridge is...
Hey i think they freze free lol and thers no tubes they are connected by chanels/ tunels blockes at the back fron freezer down. Reg temp yr nobe controler could b gone or temp module. So thats why it wont help lol check if the temp changes after yr turning it, so atleast u can iluminate that.. if it is working. Than i would sugest next checking yr front doors rubers and magnets on them all the way and both doors.. as wen it gets old it could b having gaps so there 4 it will not close the dore properly and u wont even know or notice and if thats the case. Thats why it running inside, as it not fully and all aront germeticky closed .. hooe that helps you . G/luck ??.. Tony
Apr 19, 2017 | Whirlpool Refrigerators
Hello, our fridge has stopped working, the fan and motor are still running but the unit wont get cold anymore.I think it might be a freon problem but I cant be sure. The motor and fan are running constant
Your right! A freon leakage system problem cause no cold anymore.
But a temp control must be check.
A defective temp control will also cause no cold of the freezer.
The same also if compressor motor is defective even though it is running.
Call a service technician to verify the trouble of your fridge.
I hope I give you idea regarding your fridge problem.
Jun 28, 2011 | Whirlpool ET1MHKXM Top Freezer...
The refrigerator and the freezer are staying too cold. The temp controls are at the lowest possible and still things in fridge freeze. I can hear the compressor cycle of for a while then on for a while....
things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help out.....
Jun 09, 2011 | Refrigerators
Why is everything in the refrigerator freezing, and, why doesn't the door & doors (side-by-side) close tight?
Sounds like your door or doors are being held open by an object inside. This is causing the cooling system to run constantly and thus freezing items in the fridge. Check that the shelf under the ice drawer is overpacked. the dispenser runs inro things on the shelf right under that storage compartment occasionally on my fridge. Hope that helps.
Jan 28, 2011 | Frigidaire FRS26H5AS Side by Side...
My samsung rsh1dbbp will not cool down, when it is on the freezer won't go below -20 and the fridge +14, and it is constantly beeping even when switched off? Can you help?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for the air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
I think this help in solving the problem.....
Nov 02, 2010 | Samsung Refrigerators
Both fridge and freezer keep rising in temp, seems to be running constantly. Only about 3 years old. Replaced the board in it, seemed to run quietly for one day keeping proper temps, now back to running...
when you install a new board you have to check i think it's the 9 pin connector,the instructions will tell you what one it is,if there's a wire in the second pin you need to cut the wire or the machine won't run correctly.
Aug 17, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
A M-G20010 keeps freezing coil every sevral weeks.
make sure doors close and seal all the way. are the doors being open constantly and in a high humidity area?
Is the set temp too low? How many defrost per 24 hours. Should be 4 and about 20 minutes each cycle.
Start there.
Hope this helps and let me know if I can be of any more help.
Oct 28, 2009 | Traulsen G20010 Commercial Refrigerator
My whirlpool Refrigerator motor keeps running
Keep an eye on the running time and temparture of the refrigerator. It will need time to return to normal cooling temps since the defrost and hot temps inside will take maybe a few more hours to reach normal. If not, get back with me and I will go through a step by step process on eliminations,  If so I will need age of fridge, Make and Models Numbers, Thanks Sea Breeze
Oct 27, 2007 | Refrigerators
Kitchen Aid Refrigerator Issues
Great job on the defrost drain fix, it's exactly what we do. Check that the duct damper does close fully when the refer side temps are set to warmest. It could be freezing due to that damper not closing fully or at all. It should only be open to let cold air in until the temp is satisfied then closes again. The temp control in the refer may also be failed so it doesn't know the temp was reached. The bi-metal is only there for a safety device basically to kill power to the heat elements if the defrost cycle runs too long or the area gets too hot. I'd suspect the air damper is stuck open and contstantly letting cold air into the refer side.
Feb 03, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
209 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
