Question about Canon LV 7525 Multimedia Projector
Lamp light flashing when projector turned on.
  • 428 Answers
Ordinarily this is not a problem. usually this happens to virtually every projector at start up. Reason is the projector needs to warn up before it project/beam unto the screen. But if you are saying it continues to flash endlessly, that is another issue. At any rate that doesn't seem to be the case since you didn't say so.
Posted on Sep 04, 2009
SOURCE: Lamp
I have the same problem? Anyone fixed it yet?
Posted on Feb 05, 2008
SOURCE: Flashing red status light on NEC VT45 projector
Press and hold down the help button on the remote pointing it towards the projector for at least 10 secs.
Posted on Mar 03, 2008
sabharish
  • 297 Answers
SOURCE: projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Posted on Jun 23, 2009
  • 3 Answers
SOURCE: BenQ PB8220 DLP projector - lamp button continues to flash after bulb replacement
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the lamp´s temperature circuit. A technician disassambled my BENQ PB8253 unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
Posted on Sep 14, 2009
projdoc
  • 2236 Answers
SOURCE: DLP projector fan fail so automatically turns off
replace the fans
Posted on Nov 10, 2009
INFOCUS IN102 PROJECTOR LIGHT BLINIKING
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Aug 02, 2017 | Cell Phones
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
Red lamp or heat light is flashing while projector is off. Can't be sure which it is because it is mounted 16' up. I've cleaned projector & filter with canned air from 12' ladder and red light stops...
Here is some information on this model which I hope will help...
The lamp indicator lights when the lamp is due to be replaced. It will flash if a circuit abnormality is found.
The temp indicator lights if an abnormal temperature is detected. If it goes too high it will shut down flash.
The lamp indicator is furthest away from the power switch if that helps.
If the lamp timer was approaching the end of the lamp life you would see a REPLACE LAMP nag screen when the projector is turned on. The fact that you have not mentioned this suggests that this is unlikely to be the problem.
The filters on the model are on the underside. There is a removable panel directly under the lens. You should not use canned air as you are blowing dust into the projector. It is recommended that you use a vacuum cleaner. Filters should be cleaned every 100 hours and replaced when the projector is relamped. You can wash the filter by hand with water only, ensuring it is dry before replacing it. Do not run the projector without the filter in place.
Feb 19, 2011 | Panasonic Projector Lamp for PT-LB50...
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Lamp/cover light flashes
Did you replaced lamp in projector? if yes, please make sure lamp cover is fixed properly on its position. There is safety switch under lamp cover that needs to be pressed to turn off lamp cover light flash.
Thanks.
Oct 21, 2009 | Sony VPL PX31 Multimedia Projector
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Red power, blinking red temp
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
No light come on from the projector
Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
good luck
smeags
Jan 02, 2008 | Hitachi CP-X260 LCD Projector
Canon LV 7525 Multimedia Projector Logo
65 people viewed this question
old marine
old marine
