Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
There is no output from the right side of rec out.The left side works fine
  • 135 Answers
Most likley a simple fault on the phono connector and the board it's soldered to. Check for dry joints and cracks where the sockets are mounted.
http://stores.ebay.co.uk/methleykev
Posted on Jul 06, 2010
Lost steering to left side of my new holland sl125 skid steer, what's first place to look, trouble shoot
Faulty valve in your hydraulic line or faulty motors. More likely a valve tho. Check output pressure from joystick
Aug 29, 2016 | Cars & Trucks
In my JVC RX 8SD only works a channel. How do I repair this defect?
Start with the simple things.
  • Check left right balance
  • Swap output speakers left to right
  • Swap the speakers at the receiver to make sure no wire open/short
  • Swap input RCA cables left to right red/white - white/red
Ok No JOY!
JVC has thermal overload circuits/overload on most of there Amps.
Remove power for a minute or two to see if there is a reset.
Rewire speaker connections to speaker set 2.
Connect REC out to Rec In swap cables and see if problem is in pre-amp or power amp.
Check internal fuses.
Jan 19, 2016 | JVC Audio Players & Recorders
Why is my right channel not working on my Technics reciever?
The right channel output section or speaker might have damaged. Seek tech support.
Jun 03, 2012 | Audio Players & Recorders
I have a Kenwood stereo receiver model k2 3600 , the left speaker keeps going out , the right speaker works fine. I've tried adjusting the speaker wire for the left speaker, and I always end up having...
HI,
BASED ON THE INFO YOU GAVE I HAVE SOME SUGGESTIONS BELOW..
1, switch the working right speakers cable to left output and problem left to right (from the back of receiver -not from the speakers it self..) to see if problem continues..
2.After switching them ,if it (old left new right one ) still stops left speaker cable may have short ( a tiny cable inner pieces may touching to other side ) at either at the back of receiver output or at the end ,at speaker input .
make sure you control it carefully...if the problem persist please contact to me..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 17, 2011 | Kenwood Audio Players & Recorders
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Hi i have an audio source 300 watt amp with a&b speaker outputs. the problem is that no sound comes from the left side outputs a or b. the right side works fine thank you mike
You have a blown channel. If you are experienced with electronics repair, use the right channel to assist in diagnosing the left. Both channels should be efectively identical. In most cases, the defective parts are the output transistors. You should be able to A/B the output amp sections.
Let me know if you need further assistance.
Dan
Jan 14, 2009 | Audio Players & Recorders
I Have a Teac W525R double auto reverse cassette deck and I cant dub from ;Play (left sd) to Rec. (right sd). What gives? I push rec then play on the other side and the rec stops. Then I tried the other...
Don't do either of those things. Just hit one of the DUB START buttons (NORMAL OR HIGH) Located right under the tape counter. The deck does the rest.
Feb 19, 2008 | Teac Audio Players & Recorders
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
110 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
