Question about Sewing Machines
The thread will not go into the fabric
I've been sewing on my Singer 4205 machine for about a year now. Recently I've been having problems with threading. I thread it the same exact way I always have but when I start sewing the thread will not be inserted into the fabric. The needle is going into the fabric but there aren't any stitches when I pull the fabric away.
  • Sewing Machines Master
  • 1,388 Answers
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Posted on Sep 04, 2009
The hook casing that holds the bobbin in my Singer Inspiration 4205 will not rotate when I sew. Therefor the top thread can not pick up the bobbin thread.
there could be something wrong with the hook and hook race, it needs to be checked to see it the parts are damaged or need a adjustment
Mar 07, 2015 | Singer Inspiration 4205 Mechanical Sewing...
How to fix a hook & timing issue on singer inspiration 4205?
I would over ride the auto setting and trial and error the process by manually turning the tension my self, also it has to do with the fabric too, sometimes whatever fabric is being used tends to regulate the tensioner too, good luck
Sep 01, 2014 | Singer Inspiration 4205 Mechanical Sewing...
How to thread singer 57817
here is a link for a free manual, read the manual competely thru
first and then if the machine has been sitting up for years look in
the manual for oiling instructions and then oil where it shows
and then sew on a scrap piece of fabric but don't use any thread
so the oil can move thru the machine and loosen it up,,
try using a new needle--one that is right for the fabric you sew
http://www.singerco.com/uploads/download/118_356508008.pdf
Jan 25, 2013 | Sewing Machines
I have recently bought Singer Quantum 9940 and I am not happy with the stitch. For zigzag stitch, I can see too much of the upper thread on the bottom side. This happens unequally: more on the right hand...
1. Make sure your needle is correct for the fabric. Go buy some good needles in several sizes. You'll need a 90 for jeans, rounded points for fine fabrics... get a few sizes. Your manual should provided you with clues to the right needle for the fabrics. (BTW... there really is no such thing as a Universal Needle... toss it.)
2. Re-read your manual and carefully follow the instructions on threading the bobbin and the upper thread...
3. Check your tension on the upper thread... it is too loose for the application. The tension on the bottom thread is handled by a spring on your bobbin case or race. If you do not have that threaded properly you'll have problems. Same with the direction the bobbin turns... have in it backwards... problems.
Barring all these things... It might be time for a qualified Singer repair person to look at it. Sadly Singer has seriously lowered it's standards in the last 20 years.
Feb 05, 2011 | Singer Quantum 9940 Computerized Sewing...
I just received a singer 4205 (inspiration) and the presser foot does not move back and forth to pull the material through the machine. It seems to be stuck. I am not a seamstress, but 3 other people...
It is not your presser foot, you must mean the feed dogs, they are what moves the fabric along. Clean and Lubricate your machine. Remove the bobbin case and clean it out. Replace your needle now Totally rethread the machine, according to your manual. Test the threading by putting the presser foot up, pull on top thread, it should pull smoothly, now put your presser foot down, the thread should barely move. This will seat the thread in the tension discs. By the way, try your tension on 3. Also, make sure that your presser foot is down before sewing. Always move the handwheel towards you, never away from you because you will mess up the timing. You will see your feed dogs move if you watch. Download a free copy of you manual at www.singerco.com and save it, plus enlarge the diagrams. If, that does not do the trick call Singer at 1-800-4singer.
Dec 25, 2010 | Singer Inspiration 4205 Mechanical Sewing...
The stitching on the back of the fabric is loose and the thread seems to be wrapping around the bobbin.
These are th problems typically caused by:
Improper path for the top thread.
Debris around the bobbin case.
Or a timing problem requiring the machine to be serviced.
Dec 18, 2010 | Singer Inspiration 4205 Mechanical Sewing...
How do i thread the bobbin on my Singer Inspration?
there are threading diagrams on sewusa.com
singer.com has a free operation manual in pdf form to download
on the singer home page at the bottom look for operation manuals & click on it &
in the search box put the model number 4205,, the one on the bottom is free
Dec 11, 2010 | Singer Inspiration 4205 Mechanical Sewing...
How do I thread a singer inspiration 4205
sewusa.com has threading diagrams
singer.com has a free manual to download just put in the model number in the search box
Dec 02, 2010 | Singer Inspiration 4205 Mechanical Sewing...
Singer Inspiration 4205... doesn't work!
Check the position of the bottom piece that holds the bobbin carrier to the left so it rides smoothly on the rotating hook that carries the upper thread around the bobbin. I found my wife"s machine loose so the bobbin carrier was out of position and not riding on the ledge of the rotating part. loosen two screws and push it to the left and tighten.
If upper thread bunches below the material it needs more tension so it pulls back up through the material.
If the old singers were fords this is a yugo
(been fixing and adjusting her machines for years. ))
Dec 13, 2007 | Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
