Question about LG LRE30755 Electric Kitchen Range
Scratches in my flat top Maytag electric range
My stove is only a few months old and it seems like everytime we cook we get more scratches. I have tried all kinds of cleaners including magic eraser but no luck. Scratches are not covered with the warranty, other than getting all new pots what do you suggest?
    Sergeant:
  • 222 Answers
Report the problem as "thermal cracking" and it will be rplaced by whirlpool/maytag,
these things are hard to scratch, cleaning with a FLAT edge razor scraper is the norm, there are dozens of white cream type cleaners that work well with a scotchbrite and elbow grease.
Posted on Sep 04, 2009
Scratches ceramic stove top
Good Afternoon Friend,
I understand that you have scratches on the ceramic stove top of your Frigidaire rage, model# FEF366. Small scratches do not affect cooking and will become less visible with time. To prevent any further scratches, make sure you do not use any abrasive cleaners. These can scratch your stove top even more. Try not to use cookware with rough bottoms. These can mark or scratch the cooktop surface. Try not sliding any metal or glass across your cooktop. This includes sliding your pans as well. Coarse particles such as salt or sand between cooktop and utensils can cause scratches. Be sure your cooktop surface and bottoms of utensils are clean before usage. I hope this is helpful.
-Best Regards-
WP
Jun 26, 2014 | Frigidaire FEF366 Electric Kitchen Range
Stove top won't stay on
Had a Jenn-Air cook top with the same issue. The circuit board was defective. As the unit was a number of years old it was not made anymore. The generic part was $300, and the people i spoke to wanted $100 just to drop it off. I chose Kijiji.
Mar 02, 2014 | Maytag MER6772 Gemini Electric Kitchen...
Cook top burner is scratched suface seems to be
Sorry but no repair to remove the scratches. Only way is to replace the top which is very expensive.
Feb 01, 2010 | Kitchen Ranges
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Mar 13, 2007 | Whirlpool RF365 Electric Kitchen Range
LG LRE30755 Electric Kitchen Range Logo
734 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
