Hobart 24 in. LXIH-3 Built-in Dishwasher
Problem for Hobart 24 in. LXIH-3 Built-in Dishwasher
P1 error code on LX30 Hobart
By Therinnaiguy on Sep 04, 2009
help I have a Hobart LX30H and a P1 error code. Can anyone help?
Best Solution
posted on Sep 12, 2009
Very Helpful)
Rob-OES
Rank: Guide
Rating: 100%, 3 votes
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" You were right! can you help mr with a P2 error code? " - Therinnaiguy
Popular Solutions for Hobart 24 in. LXIH-3 Built-in
Questions and Unsolved Problems for Hobart 24 in. LXIH-3 Built-in
Do you recommend Hobart 24 in. LXIH-3 Built-in Dishwasher?
Answer
Answer
I have a Hobart HD-20 home dishwasher that is leaking at the bottom left corner on the final cycle.... (More)
Answer
the lxih is stuck in delime. It runs "wash" then did "rinse" x1 and then just... (More)
Answer
I cannot find a soap and rinse distributor for a Huber home under counter machine. How can I get the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart 24 in. LXIH-3 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
