Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Distorted picture triple colors warped screen
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
You will also want to replace the white heat sinkdistorted picture triple colors warped screen - 2.gif compound that is on the heat sink, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 04, 2009
The picture is distorted as well as the color
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 20, 2010 | Panasonic PT-51HX42 51" Rear Projection...
The color is distorted and the picture blinks. I've replaced the lamp twice before and i don't think this is a lamp problem.
*Screen Looks 3-D
*Colors wont align
May 15, 2010 | Toshiba 52HM95 52" HDTV Projection...
Colors seem to be out of sync
Dull Video...
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
May 14, 2010 | Philips 55PP9401 55" Rear Projection...
I have a samsung 65in hdtv rear projection and the colors dont line up it looks like triple vision what could it be
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Samsung HCN653W 65" Rear Projection...
Triple colored ghosts
*Screen Looks 3-D
*Colors wont align
Apr 17, 2010 | Sony KP-43T90 43" Rear Projection...
Funny colours on screen?
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
Apr 01, 2010 | Televison & Video
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hello, I have an older Pioneer SD-P55A3 projection tv. I have a problem where the picture at the bottom of the screen appears distorted or, more accurately, "warped". There is yellow and blue that does not...
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Mar 16, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Warped picture Toshiba 65HDX82
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
Distorted picture on RCA LCD TV
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
143 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
