The washing machine wont rinse - Kenmore echo care system
The machine is 5 years old. The machine is not rinsing or doing the final spin, leaving the clothes all soapy and wet.
    Sergeant:
  • 222 Answers
Without more info its hard to tell but it sounds like a bad timer. can you advance it manually a few notches or run it in another rinse cycle.
Posted on Sep 04, 2009
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Jan 20, 2013 | Kenmore Washing Machines
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Wash cycle stops
This is a relativly simple solution... The washer probably wont spin either... Thanats due to a bad lid switch. Try replacing mthe lid switch and go from there.
Apr 03, 2009 | Kenmore 24032\24036 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Water wont leave the machine in rinse or spin cycle
Sounds like you have a broken lid switch, most likely part # 3949247,,#11 on diagram. Dave www.washermd.com
Dec 08, 2008 | Kenmore 22422 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Bosch WFL 2860 Stops Part Way through Its Cycle
When a machine stops during its rinse period, it is normally a block in your outlet filter. And you say it has not been maintained in any way for 5 years; at least you shd be doing the minimum maintainance like clearing your outlet filter.
Front bottom right, is where access to the filter normally is; get to it and clean out, plug off the wall first. The large plastic is to be turned anti-clockwise to remove, refit carefully after cleaning.
Nov 25, 2007 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
