Question about Dell Axim X51 Pocket PC
My Dell x51v Axim suddenly no longer communicates thru ActiveSync. Even though it is firmly connected with a USB cable, ActiveSync will no longer recognize it. I have uninstalled and reinstalled ActiveSync, and now cannot set up a new partnership since it does not see the PDA.
  • 2,200 Answers
First try a "soft reset" - this clears all open programs and "reboots" the Pocket PC. When the Pocket PC powers back up, you'll start with all active programs closed and the device should be ready to use. This procedure is intended to reset the Pocket PC if it is malfunctioning or has become bogged down.
This reset is also sometimes necessary after software is installed.
The X51v can be soft reset by pressing the recessed button on the rear of the unit above the battery.
Try to reconnect with your PC. If that fails - on the Axim - go to start - settings - connections - usb to pc and untick enable advanced network functionality - then see if you get a connect.
If you are still not getting a connection you will have to try a "hard" reset. However be aware that a "hard" reset wipes the RAM and returns the Pocket PC to its factory specs.
In effect, the Pocket PC will be just as it was when you purchased it.
All data entered, preferences set or software installed (other than ROM updates) on the Pocket PC after purchase will be lost after a hard reset and will have to be transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
The hard reset is performed through the following procedure;
With the unit turned on, press and hold the power button at the top of the unit. While holding the down power button, use the stylus tip to press the "Reset" button mentioned above. Allow the screen to fade to off. Release both buttons. The unit will power back on and display a menu to confirm the hard reset request.
Make sure you have downloaded and are using the newest version of microsoft activesync.
Try the reconnect and let me know how you get on.
Hope this helps. Please do rate my answer. Thanks.
Posted on Sep 04, 2009
I have the same issue, but don't want to lose all my data. What in the world changed with ActiveSync that caused this issue all of a sudden? So frustrating!
Posted on Dec 31, 2009
Axim x51v won't sync
Guys it's probably down other sync software on your system like phone sync, I had the same problem yesterday, sometime ago I had installed software for my HTC phone, check in add/remove programs & uninstall anything that sync with your computer, then reinstall activesync.
welshcob
Jan 03, 2013 | Dell Axim X51 Pocket PC
Looking for sync software for Axim x51
ActiveSync is all you need to sync with your Axim. Make sure you download the appropriate software for your OS. Drivers are available at microsoft.com
Jan 28, 2010 | Dell Axim X51v Pocket PC
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
My Dell PDA won't sync with my PC, although it used to?
1)If you get an error message from ActiveSync on your PC, it's one of a million things that can and do go wrong with another piece of Micr0$0ft'$ "finest". I wont even go there in this post. 2)If it just never gets seen by the PC, check your USB cable connection. 3)If the PDA doesn't even turn on and/or charge immediately when connected to the cradle, you may have a bad cradle. 3a)If the connector in the cradle feels lose or it DOES connect if you hold it a certain way, your cradle's broken. They're known for this.
Oct 07, 2009 | Dell Axim X51v Pocket PC
We have a Dell Axim X5 that we are trying to connect to a PC. Have obtained a USB data/power sync cable, the Dell appears to charge from this cable however, ActiveSync on the source PC doesn't recognise...
I use AS 4.1. I think the Axim will use up to AS 4.5. I had no problems with sync until SP3 came out. Now I must resart the computer with the Axim connected to sync. If the computer goes into suspend it will no longer connect until restarted.
Attempt a restart with it connected.
I have known others with no ability to get the Axim and other devices to be recognized. Unaware of a solution in that case.
Jul 13, 2009 | Dell Axim X5 Pocket PC
I have installed active sync to link to my aximx51 but it can not detect it
have you upgraded to 4.5 active sync. If so turn off the advance usb function located in setting and then connections. This worked for my axim x51v
Sep 15, 2008 | Dell Axim X51v Pocket PC
Dell axim x51v and dell d810 conflict
Thats an easy one, simply uninstall your active sync reboot with axim of cradle then install newest version here : http://www.microsoft.com/windowsmobile/activesync/default.mspx
Aug 05, 2007 | Dell Axim X51v Pocket PC
Will Dell Axim sync with Outlook 2000 on Windows 95?
It should if you have USB on the W95 machine. ActiveSync is compatable with W95. It worked for me with Outlook 98 on a Win95 laptop synching to a PC2000 PDA (Jornada), however I was using a serial cable.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X51 Pocket PC Logo
359 people viewed this question
Alun Cox
