Question about Canon FAX-L800 Plain Paper Laser
Canon FAX-L800 showing "replace cartridge" message although cartirdge is not empty and even after changing it with a new one, it still shows that message. we have received faxes in the memory and can't get them out!! help! any ideas? particularly about getting those faxes out e.g. by on-faxing them to another fax machine or something?
  • tala785 Sep 06, 2009
    still couldn't forward the faxes from the memory but managed to find info in the document you sent me to get the printer to disregard the cartridge problem and print the memory contents anyway, which is what we needed to do.
    Thank you
  • 2,200 Answers
Hi
You can set the unit to transfer the documents on to another fax. This is quite a longwinded process so I have included a link to the manual for this model as you will need to study this before you can achieve the transfer and my post would be running into several pages otherwise.
The link is here and the section you need to look at begins at page 141 on chapter 7-11
http://ww2.canon.hu/download/kezikonyv//fax-l800_Users-Guide_ENG.pdf
I realise you need to get these faxes out urgently so I am rushing my answer a bit!
In regards to the problem with the replace cartridge - I would recommend that when you get your faxes through you disconnect the machine from its power supply for 30 minutes then power up again to see if the issue resolves.
If not it is possible that the cartridge itself is faulty.
I hope this helps. Please do rate my answer. Many Thanks.
Posted on Sep 04, 2009
  • Radio Code Pro
    Radio Code Pro Sep 04, 2009
    A few things to add in relation to your cartridge problem and to eliminate any of these as possible causes.
    1) Ensure that you have removed the plastic seal from the side of the cartridge itself prior to installing it.
    2) The cartridge should be rocked from side to side a few times to evenly distribute the toner
    3) Ensure you have seated the cartridge properly on the rails and closed the lid firmly using two hands
    4) Ensure that when you have installed the new cartridge you set the RX to memory.
    Thanks for using FixYa.
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
I have put a new Cyan ink cartirdge in put it will not print
Make sure the cartridge is full y inserted if not will not print and it will aslo not display.
Aug 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Fax L800 dead?
there are fuses on the power supply board
Sep 02, 2008 | Canon FAX-L800 Plain Paper Laser
Is there a fuse inside the L800
You probably have a dead low voltage power supply.
There might be a fuse on it, but a blown fuse usually indicates a bad power supply.
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Hloo I need hilp
sounds like you have an empty ink catridge. even though the catridge doesn't look complete empty the sensor can decide it is and won't work until you change the cartridge. You might want to remove and reinsert all of the cartridges making sure they are in the proper slot and properly setted.
May 05, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Deleting speed dials on canon fax L800
you should be able to delete the speed dials by lifting the two speed dial pannels and you should get all the configuration butons showing. ress the speed dials button (think its on the middle of the bunch) then delete at bottom right. this should then ask which entry you want to delete ie. entry No 1,2,3,4 ect Hope this helps Cops Pete@wedotoners.com
Sep 24, 2007 | Canon FAX-L800 Plain Paper Laser
How to set ringtone when receiving fax Canon Fax L800
RINGER IS SET TO SILENT MODE,PLEASE CHANGE IT HAPPY FAXING OMNIPRESENT
Sep 19, 2007 | Canon FAX-L800 Plain Paper Laser
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
Canon FAX-L800 Plain Paper Laser Logo
old marine
old marine
