Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fridge not cooling
The problem to my fridge not cooling is in the mother board so Iv'e been told so what do I do?
After 2 years our fridge was beeping and not keeping food cold, when we were having people over for xmas lunch. Luckily was still under extended warranty. The wires of the fan had broken and was not pushing the cold air around the fridge. 2 years later fridge is beeping again, assuming its the same problem. The fan is a cpu computer fan, so if you have anyone handy its easy to replace, fan is located under bottom panel of fridge section.
Posted on Sep 08, 2009
    Problem Solver:
  • 11 Answers
Get someone out to fix it...
Posted on Sep 04, 2009
3 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Posted on Jan 10, 2009
  • 8 Answers
SOURCE: fridge not colling-hotpoint HSS25GFPAWW SIDE BY SIDE
It could be one of many problems but will most likely be a refrigerant leak in the refrig evaporater
Posted on Jan 23, 2009
My fridge and freezer stopped working. Nothing's running. It doesn't cool or freeze. None of the mechanical parts are working. Only the lightbulb turns on. What can be wrong?
if removing the mother board made no difference to the fridge operation then it would be logical that the mother board is faulty
These machines do not like power surges( can originate many miles away)
have a technician check it out
May 06, 2015 | GE Refrigerators
Fridge check light is on and fridge not cooling
disconnect thermistor on back board let run if ok replace if not bad board or cooling unit
Apr 02, 2013 | Dometic RM2852 Refrigerator
My fridge just stoped working. i have checked power to the cooling system and get no power. i checked power to the (mother board) i get power all the way throught till i plug in the connecter to the...
it is or may be the mother board . very common . ck the printed pc board . it may have a bad soder joint .. very common .. .. most no go like yours are the pc control in the back . mm hope this helped feed back pls ..
Sep 19, 2011 | GE GSL25JFPBS Side by Side Refrigerator
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
I have a GE fridge model GSH25JSTSS and both the fridge and freezer are not cooling and the front panel is out (nothing lights up anymore on it). I've been told I need to replace the mother board, but it...
You need to test wiring harness and connectors, and control board. (motherboard) seems to have a control board problem.If your not getting 120 volts in the light socket then you have a board problem check for loose wire at the control board.Hope you rate my response.Thanks
Feb 03, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
Electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Jan 08, 2010 | Electrolux Refrigerators
Maytag MFD2560HES not cooling. Turning breaker off/on resolves
Hi!!! how old is the frig?If it has a mother board that is electronic then you have a bad board.main electronic boards could be very expensive but you can save the labor and the headache by just buying the board and install it yourself..good luck..
Jan 03, 2009 | Maytag MFD2560HES Bottom Freezer French...
Amana fridge stopped working. Now working again.
ok..so that is the mother board. it is not a mechanical timer but the adaptive defrost is integrated to the controller of the whole fridge.
anyway, look at the lower back portion of the fridge, near the wall , at the compressor compartment is a housing of the mother board. you won't miss it since a lot of wires goes to that box. unplug the ref, remove the cover of the box, remove all the wires attached to the board, and replace it.
i hope i was able to help and please do not forget to rate on the original post.
tnx 4 using fixya,
drcool
Oct 30, 2008 | Refrigerators
Ice maker motherboard
call the manufacture, sounds like an issue with the circuit board
Feb 19, 2008 | Maytag MFD2560HES Bottom Freezer French...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
524 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
