Question about RCA R52WM24 52" HDTV Projection Television
52" rca hd proj. tv model # d52w23
Could someone please give me the part# for the convergence ic for my 52" rca proj, hd tv? pic drop at the top & arch at the bottom ,concaving.
colour out of whack.i checked soldering on all boards,no cracks.convergence adj.dont help.ic on [blue colour]convergence board reads different from the other 2 on red & green convergence board when tested.if the ic is replaced correct ,which i can do,should do the fix.
  • SD Tech
    SD Tech May 11, 2010
    FYI: THESE sets do not use a convergence IC; the convergence is spread across 3 circuit boards; I do not repair them because of problems getting parts for them---look for someone in your area who is willing to fix it--not the best set for this kind of problem--Google the model number and you will find everyone with one of these has this problem.
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC, whick you have found to be true.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
You will also want to replace the white heat sink52 compound that is on the heat sink2.gif, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 04, 2009
    Problem Solver:
  • 10 Answers
I bought a kit from this place and fixed my problem. Can't beat $25 price
http://www.tvrepairworld.com/contact_us
Posted on Oct 04, 2009
    Problem Solver:
  • 13 Answers
SD Tech is correct. These sets do not use convergence IC's. The part you're looking for is the FL231 fuse located on the deflection board. It is located right next the the flyback transformer.
This is a very common problem. Replace the fuse and re-flow the solder at the flyback and you should be good to go. Check capacitor CL230 and replace if bulging.
Here is the fuse I'm talking about:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=220478092023
Posted on Oct 01, 2009
I have an RCA D52W23 TV convergence problem
bd pt no is 264103 check your local rca dist and servicers
Oct 23, 2009 | RCA D52W23 52" HDTV CRT TV
I need to find out where the convergance box is located or what it looks like.
Your model doesnt have the normal Convergence ICs that are associated with most other rear projection TVs. www.tvrepairworld.com can assist you with waht you need for your RCA
Oct 11, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
What is the part # for a rca hd tv convergence ic. model # d52w23 & where is it available .picture concaving ay top & bottom,colour out of whack.
The part number for the convergence ic's are on the ic, they all start out with stk392-??? if it is a 110 thorugh a 150 you can use a stk392-180 to replace the orignal one, if it is a 560 you must use the same stk392-560 ic.
Sep 01, 2009 | RCA D52W23 52" HDTV CRT TV
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Need part # for convergence IC:s on this mdl D52W23
I think theis set have transistors. They are on a board across the back of the set just under the mirror
Jun 30, 2009 | RCA D52W23 52" HDTV CRT TV
RCA HDTV D52W23- words in 3D - picture at top and bottom black
are you still having this prob? i am having a similar prob with the same brand of tv. if you had yours fixed please help me with mine.
i think it is the convergence ic. i need three ic but the distributer will nit sell no less than ten of them. if you or anyone need any of those ic i could let you some for the same unit price i bought them. posted 09/02/2009
Jun 28, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W23 convergence chip
THERE is no convergence ICs on these sets it does have convergence board it has serveral ALuminnin heat sinks on it If comcast was at fault it would have fried your SSB board which will shut TV down Cost of Board is 352.00
Feb 13, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Dec 21, 2008 | RCA D52W23 52" HDTV CRT TV
Converges problem for my RCA 52
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WM24 52" HDTV Projection Television Logo
453 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
