Question about Kenmore 62622 Microwave Oven
Kenmore 721.63662300, 1200W
It started making a high pitched buzz or arc sound when first cooking for about 2 -3 seconds into the cook time. Now it doesn't make that new noise, it warms food some, but does not heat well.
  • mad dawg Dec 29, 2007
    My Kenmore over the range microwave recently started making a loud buzzing sound.  When that happens, it doesn't heat up the food, and appears to smoke and smell funny.  The microwave is about a year and a half old.  Any suggestions?
  • 579 Answers
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try
Posted on Dec 31, 2007
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
Noisy microwave on first Start... Not noisy on subsequent Starts
Does it sound like a fan blade rubbing?
Can you make a short video and upload it or share with me directly?
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 18, 2017 | GE Microwave Ovens
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
Sharp R959SLMA
Could be arcing around HV transformer or even an HV wire, Sometimes an insulator on a capacitor will get old, dusty or breakdown and arc between the terminals. Have you ran this with the cover off to see if you can see any visual arcing??? If it cooks sure sounds like it is probably not the mag. Something supplying power to the mag arcing to ground I would expect.
Aug 18, 2017 | Sharp R959SLMA 900 Watts Convection /...
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Sep 08, 2008 | Kenmore 63662 / 63664 / 63669 Microwave...
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore 62622 Microwave Oven Logo
365 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
