Question about Philips 50PF9631D 50 in. HD-Ready Plasma Television
How difficult is it to replace the power supply unit on my 50pf9631d tv?
  • 214 Answers
Its difficult
Posted on Sep 04, 2009
    Top Expert:
  • Philips Master
  • 14,553 Answers
The problem is you have to remove the back (lots of screws) and the board is expensive: Part number has changed and is: 996500042147---it retails for 305 dollars----I would not buy a used or repaired board if I were you--this is the problem with all plasma sets--they only sell boards--the ones for the Philips set are expensive.
Testimonial: "Thank you. I was all set to buy the refurbed part at $193.95 from partstore.com, but now I won't. Thanks again."
Power goes out on Phillips 55 in tv. Model 50pf9631d/37. I am suspecting power board
That would be my guess, could also be a safety circuit detecting out of range parameters. But most likely a bad capacitor on the power supply board/module.
Jul 16, 2017 | Televison & Video
The television Philips amberlight 50PF9631D will not go on and just flashes red, even when unplugged for the duration mentioned and then plugged in. Been having this problem for over a year and now worn...
No recall,very common problems for LCD and Plasma tvs sets.The problems ur tv are having is it the causes by the tv power supply board.That the board where the power a/c cord plug into it.U have all the tools and know basic electronic aslo can do soldering work too?Yes?Take the tv aparts and check the tv power supply board carefully,searching for dying and soon to be dead components parts are calling capacitors parts.These components capacitors parts are dying and soon to be dead are leaking,it is alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors parts must be replaced.Replaced those capacitors parts are dying parts with the same Micro Fared and the voltages higher rating like 5 or 10 voltages higher will held up and with stand heat better than those old dying capacitors was in there.Or have the tvs shops services it?Or try Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 04, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
7 red blinking light. Tv not turning on. I replaced the 2 blown capacitors
The caps you replace was it from the power supply or the mainboard?
Thanks
Nov 22, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Will not turn on it just flashes a red light on the front corner
Try unplug,replug the tv about an hour later,let it reset itself.The tv should work again.Not,than the power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 06, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
My Philips 50pf9631d plasma tv turns on then red light blinks 7 times! Philips no help. Local electronics store wants $500 to fix! Set is only 3 yrs old! Please help.
Are you getting picture or sound at all? If not, you could have a very common power supply failure. If you get sound or picture, then you may have a faulty capacitor or resistor on one of the system boards
Aug 29, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50pf9631d ambilight has gone out on one side, how do I repair it with out paying philips (or an authorized dealer) outrageous rates, for a problem that has clearly affected MANY Ambilight owners? This is...
ok its possible it is the light itself which would be cheaper- or- it could be the ambilight driver- each ambilight has a driver that tells it to turn on supplys power etc-its not difficult to change-usually located on either one side and the lights all run from it or one on each side-depends- its small rectangular and you can follow the wire from the light back to where it plugs in to the driver- try shopjimmy dot com for parts
Aug 18, 2009 | Televison & Video
Philips 50PF9631D Plasma
First step....check power supply components.....research
similar Model & problem.................T.
Mar 22, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Won't turn on
i have replaced many SSB's on this model but obviously cant be sure
expect to pay 400-500 part and labor
Feb 27, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 50PF9631D 50 in. HD-Ready Plasma Television Logo
343 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
