Question about Kenmore Washing Machines
The washer is not spinning and it is giving a code of 02F.
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
CLICK HERE
for a great tip by JSRock on accessing the pump screen to clean it out.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa!!
Please accept this answer to remove it from the work queue.
Posted on Sep 04, 2009
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: washer is giving me a code 02F
"F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the lower toe panel directly below the door in the FRONT of the washer. They are located under the bottom front edge of the panel. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Posted on Feb 25, 2010
rylee_smith
  • 8619 Answers
SOURCE: 02f code
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 20, 2010
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
Sometimes the water will not drain out, of my Kenmore Elite HE3 washer and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, won't drain, nor will it...
Hi, You pump filter screen is clogged up of you may even actually have something stuck in the pump. Unplug machine, remove the bottom front panel 2-3 screws along the bottom. look for the filter/screen housing next to the pump. place a shallow pan under it. Be prepared for lots if water and debris. Unscrew it slowly to drain then screw it back in to shut off and dump pan repeat until no longer full of water. Remove and clean all debris out screen, housing and hose.
Nov 01, 2010 | Washing Machines
Sometimes the water will not drain out, and it will display 02F. The door will not open, when I press the drain/spin button it makes a funny noise, but sometimes it will work just fine for a couple of...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 24, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
02f code
Hi
Thanks
Rylee
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is giving me a code 02F
repairclinic.com
Feb 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite HE3 front oading washer says 02F
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 18, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet won t spin continues to beep and
Jun 16, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite Oasis HE top loading washer model #110.27082602 gives me error code F50 and doesn't spin. Other blogs tell me that it is possibly a main control board. What do you think?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Mar 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
