Question about Dacor Prefrence PRV36 Stainless Steel Kitchen Hood
The fan buttons on prv36s ventilation unit do not activate with a gentle touch any more. What can be done to correct this?
  • 530 Answers
It's hard to say. It depends what caused the problem. If the cause is simple wear then replacing the control unit is really the only thing you can do. However if moisture, grease or grime has managed to get in and around the contacts under the buttons then cleaning would help. The problem is that the only way to clean that area is to disassemble the control unit. So your going to have ask your self just how annoying it is. If it's becoming unusable then it should be replaced. So you really have nothing to loss by attempting to clean it. It really depends on your level of comfort with taking things apart.
I would also get in touch with Dacor and explain the problem. It's possible your problem might not be uncommon and they may have something in place to deal with it. Below is the link to there home page.
Good luck.
http://www.dacor.com/
Posted on Sep 04, 2009
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
I have an HP Pavillion DV5-1125NR Entertainment Laptop. I have the touch screen above the keyboard and the wireless button is there. I had my fan replaced and now that wireless button will not respond -...
You need to take it back to whomever replaced the fan because the wireless button ribbon came loose and it is simply not activating your wireless device as it should. These are ribbon cables typically that are flat and slide into sockets that then lock in place. When it was taken apart to fix the fan, they obviously did not get it slid back in properly or forgot about it all together.
Oct 31, 2013 | HP G60-120US Laptop
Runs hot
Possible that the processor cooling fan is clogged as it can happen if the laptop is worked on top of beds or cushions wherein it can **** up fiber and clog the fan or the cooling systemYou can remove the processor unit from the bottom, inspect the ventillation windows and clear the dirt and reset
Jan 09, 2012 | Panasonic Toughbook Computers & Internet
Error fan check message always appear when you turn the DVD on
Page 32 of the manual:
http://www.retrevo.com/support/Samsung-HT-Z510T-Home-Theater-Systems-manual/id/14714ci454/t/2/
Cooling Fan
The cooling fan supplies cool air to the unit to prevent overheating.
Please observe the following cautions for your safety.
Make sure the unit is well-ventilated. If the unit has poor ventilation, the temperature inside the unit may rise
and may damage it.
Do not obstruct the cooling fan or ventilation holes. (If the cooling fan or ventilation holes are covered with a
newspaper or cloth, heat may build up inside the unit and fire may result.)
So look at the fan and make sure it's turning. Pick out the dust balls. Give the system room to breath (Page 13: 4" clearance from the fan)
Feb 07, 2011 | Samsung HTZ-510 Theater System
I have a viking vipr161ss ventilation system. When I push the button on top of the ventilator nothing happens. When I manually activate the microswitch located in the electrical box under the cabinet the...
Hi- It sounds like you diagnosed the problem correctly. There is a chance there is something wrong with the board but I would replace the top switch first. They are pretty expensive if I remember correctly and be careful of the wiring colors, the last one I changed had the wire colors reversed but the wire labels were correct. Good luck.
Sep 24, 2010 | Viking VIPR Series Versavent Kitchen Hood
Protect circuit activated........where to look for defects?
Typically a shorted speaker output. CHeck where your speaker wires are and see if there's just one wisker of wire touching the adjacent terminal. Check the back of the amp (easier said than done) and then check the back of the speakers themselves. Second most common issue is overheating. People leave an LP covering the ventilation openings on top of the amp and wonder why it overheats, so make sure you have air ventilation. Speaker wiring, then ventilation. Unplug unit, plug back in again, and power on and see if your problem goes away; if not, come back and we'll see what else we can try for you - okay?
Aug 13, 2010 | Sony STR-DE615 Receiver
Overheating too fast.
There's a cooling fan on the back. Is it clogged up or otherwise not turning when hot? From Page 21...
■ Make sure the unit is well-ventilated. If the unit has poor ventilation, the temperature inside the unit
may rise and may damage it.
■ Do not obstruct the cooling fan or ventilation holes. If the cooling fan or ventilation holes are covered
with a newspaper or cloth, heat may build up inside the unit and fire may result.
May 04, 2009 | Samsung HT-X40 System
My dacor prv36s ventilation unit is making noise
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 22, 2009 | Dacor Prefrence PRV36 Stainless Steel...
Unit overheated due to fan malfunction.
Again EA or EC error codes? To unplug the fan you really have small hands. Fan is a unit not just motor, explosion proof and costs over $330.
If that was a popping or staccato noise it wasn't the fan but the gas valve. Sounds like water penetration which condemns the gas valve a $237 part which FYI DIY you can't replace unless you're a Tech.
What's with your warranty?
The pilot in an electronic Bosch doesn't exist, it's lite by a spark . igniter.
This is a Gas Appliance which requires a RSA to service.
If water penetration then change your termination box to drop dead by Z-Vent. We change dozens of these (GV's) a year due to this crappy box. These units work best when Direct Vented.
Jan 24, 2009 | Bosch AquaStar 2400ES-NG
Garmin Street Pilot C330 - screen problem
This doesn't fix Sitfar's problem, but for those how might find this helpful from Garmin's site: Question:  The touch screen is not responding correctly when I touch it. How can I recalibrate the screen?
Answer: To recalibrate the touch screen:
  1. Turn the unit off.
  2. With the unit off, touch and hold the Power button for 30 - 40 seconds.
  3. Follow the instructions on the screen.
May 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Kitchen Ranges Logo
440 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
