Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Paper Jam on the Canon Imageclass MF6530
I am getting a " Paper Jam open left cover" error, but all my paper is cleared. Could their be a piece I am mission (but I thouroughly checked) or do I have to reset something.
Thanks!!
  • Fearless Dec 10, 2007
    Thanks for the prompt reply!
    I have checked all rollers etc.. and cannot find any paper. This was the first thing I did check prior to contacting FixYa.
    Could a sensor be blocked by something else or can I do sometype of reset.
    Thanks,
    Fred
  • Anonymous Mar 17, 2014
    paper jam - opened back - when removing jammed paper, corner piece of paper tore off - cannot find it to clear the jam.
    President:
  • 317 Answers
Make sure that there aren't any tiny pieces of paper stuck in any of the rollers or gears. This can cause that as well.
Posted on Dec 10, 2007
  • Peter Burns Dec 20, 2007
    Check that the type of paper being used falls
    within the printer manufacturer's recommendations. For example, paper
    designed for ink-jet printers doesn't necessarily work well in laser
    printers. High-quality, bonded paper will cause paper jams in some
    printers; look for bonded paper that is "laser and ink-jet compatible."
    I
    nspect the
    printer's paper rollers. They should be smooth but not shiny. Rollers
    that are cracked or glazed are a frequent cause of paper jams and
    should be replaced by a technician.
    Try cleaning the printer's paper rollers with a
    lint-free cloth and isopropyl alcohol (available at electronics shops
    or drugstores).
    Try changing the toner or ink cartridge.
    If you hear a clinking sound during printing,
    your printer probably has a broken gear and needs to be serviced by a
    technician.
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
My paper jam error will not clear, on an above answer it says to check the sensors..I don't know where to find the sensors. There is no paper stuck in printer, the paper was pulled out whole.
Unplug the printer for about 5 minutes and try again, if still gives error, try uninstalling and reinstalling the printer. If that doesn't work try running a heavier stock paper (thicker) through the printer following the normal path, sometime the tiniest piece of paper will causea jam error message.
Here is a link to the user manual in pdf. Just enter your email, enter the captcha code and you can download the manual which should have sensor locations and troubleshooting information.
Hope this helps
Dec 07, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Paper jam is now clear ,still shows error light and con like there is still a paper jam how do i clear this error. machine will not operate
If you reset the copier by open and close the top scanner, by moving it left and then right, and you still have a paper jam error on this model there are only 2 options one that there still a piece of paper holding the switch, 2nd option is that the switch is broken or out of place. If you remove the paper from the fuser, the left side of the machine, where it exit, your only option is to take the fuser unit out, and check the switch, recommended for technician only!!!
If you found the paper at the right side of the copier, take out the cartridge, lift up the metal plate on the bottom, swing it up and look for the paper.
Good luck.
Dec 02, 2010 | Canon imageCLASS D760 All-In-One Laser...
Paper jam says "open left cover"
Open the LEFT cover, and remove any jammed paper.
Close the LEFT cover.
Mar 26, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Paper jams, it won't pick up paper from the tray, jams every time. Have tried different paper but that doesn't seem to help.
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Aug 27, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
899 people viewed this question
old marine
old marine
