Question about Ovens
Cleaning spill that has acculumated between the two panes of glass that make up the front of stove...? Any ideas?
  • 725 Answers
The only way to do this is to take the panes apart, clean and reassemble. This takes time and patience, but I'll bet you can do it. What ever brand it os, go that web site and see how many pieces there are to the panes. Then plan to a spend a couple of hours on it. Hope it works out great for you.
Posted on Sep 04, 2009
Removal of inner glass door.. how.??
Open door to about 15~20 degree angle, pull up on door and totally remove from stove. Lay face down on flat surface. Now can access all screws to separate the inner and outer panels and to replace the glass. To return to stove, use locking pliers to pull the door hinge stubs out to their 15 degree open position, slide door on and close.
If glass not broken, just can't see through, no need to remove door or glass. Use glass cooktop cleaner, apply and let soak 3 minutes, then use new single edge razor in holder to shave off the baked on grease. May have to repeat 3x then switch to glass cleaner and clean again 3x, should be quite clean and clear unless seal has failed on the double pane thermal glass and internally obscured in which case the only cure is to replace the glass... return to paragraph 1.
Sep 20, 2015 | Ovens
The inner pane of glass on the oven door has shattered. Can I get a replacement?
Yes you can, your best bet. Try to go to manufacture of your stove.
If they discontinued then try the web
Jan 03, 2015 | Stoves 720EF Electric Double Oven
Ariston oven window pane out
Take a look at http://ovendoorglue.co.uk/fix-oven-door-glass/ whish should help explain how to remove the oven door, take off the fascia and glue the inner glass.
Oct 28, 2012 | Ovens
My self cleaning kenmore stove seems to have grease between the window panes on the door. cleaning doesn't reach this problem. i need to get between the panes to clean them - how can i do this? will...
Taking the door apart is relatively easy and unfortunately the only way to clean between the two pieces of glass. All you need to do is remove the screws holding the outside cover on.
Jul 01, 2011 | Ovens
Good morning; We have a new Jenn-Air black glass
Any proprietary glass top cleaner should be suitable. Avoid using a wire based scouring pad but the Scotch type 'plastic/foam' cleaning pads are ok.
Jan 04, 2010 | Jenn-Air Ovens
Securty door top glass broke
Your problem shows a stove, but I am guessing that you are talking about a door to your home. Use the Yellow Pages directory in your phone book (online FixYa does not provide local physical assistance) and look up GLASS companies in your local area. Call and get a quote for someone to come out and install a new glass pane in your door. If it is a security door, it will probably be TEMPERED glass. Hope this helps. If so, please rate me as helpful.
Jun 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Door
I have spilt water inside the glass of my Fridgaire stove and wondering how to take the glass off the front so I can clean inside it.
Jun 02, 2008 | Ovens
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
