I am using Microsoft Works 8.5 and Windows XP Home. I want to be able to put a graphic and text into a table. I would like to either use a text box in a cell or wrap text around the graphic. I can not do either. I am trying to make name badges. Must use Works.
  • 6 more comments
  • donna406 Sep 04, 2009
    Thank you for your response. However, it doesn't work.
    I already have the name badges bought and have made them in Ms Word without any problems, but I now need to do it in Ms Works.
    I went to Tools>Labels and went to the Avery label, but it still creates a table, and I can not bring in a text box or can I bring in a graphic and then apply text wrap tight.
    There doesn't appear to be any way to bring in the grapic and then get the text to type along side of it.
    If you have Works, try it, and see what I'm missing.
    Thanks so much.
    Solution #1 is identical to what I tried to do except I made my own table instead of using Labels and Avery label. The problem is still putting a graphic and wrap around text in the same cell. I would like to solve this with a text box, but it appears you can not put a text box or make a graphic with wraparound text in a table cell.
    Does anyone have a work around?
    Thanks.
    Donna
  • donna406 Sep 05, 2009
    Yes, I have tried to take my Word template, which is a table, and bring it into Works. It doesn't work. When I try to do a Save As in Word, saving to .wps it quits responding. I have Word 2002.
    When I try to open a doc program - my table - into Works 8.5, it only brings in the last two cells. I have four rows and two columns.
    I have done updates on the programs and they are up to date, albeit not the latest.
    Any other ideas.
  • donna406 Sep 08, 2009
    I have been able to transfer documents from Word to MsWorks, but I can't do it with tables. And of course, the original problem I can not put a wraparound graphic or a text box in a table cell in Works 8.5. Please would someone who has Works 8.5 try it on their computer to see if there is a way to do this.
    I do not want to put this in a web site which I think is what you are explaining, CSS appears also to apply to web sites.
    My problem is straight forward using software Works 8.5.
    Please rethink your response.
    Donna
  • donna406 Sep 12, 2009
    This appears to work great except I've forgotten a lot about how Paint works.
    I made my table in Works, put the images in, copied the table and pasted it into Paint.
    I was able to get the text in fine. My problem now is I can't print the table as I thought it should be.
    What is it about my procedure or printing that doesn't appear to work.
    Thanks so much - this is the first solution that came close to working.
    Donna
    I didn't read the last part of copy/pasting back to Works. This doesn't work. I get nothing.
    Any suggestions?
    Donna
  • donna406 Sep 24, 2009
    dnewcomb1 - You were solution #1, and now you are solution #5 with the same answer. I sent you a reply on September 4th which you failed to answer. Please check above for the replies and give me an answer to that.
    Thanks.
    Donna
  • 284 Answers
Hi There,
I couldn't find much info on this problem.
There are a couple of suggestions here but I'm not sure if it will help.
http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.works.win&tid=ef689220-fa5d-4571-b00e-99f05fac0e0a&cat=en_US_77e075ae-c07c-4ce8-aac1-e366715b1549&lang=en&cr=US&sloc=&p=1
Posted on Sep 12, 2009
  • 11,896 Answers
I have 8.5 I start project here. Copy and paste to paint. Add or edit. then copy back to works and save as works file.
Posted on Sep 09, 2009
  • 3,741 Answers
There are two common methods explained here for wrapping text around images in HTML: Theimage attribute method and the table alignment method. You can also use CSS to wrap text around images explained here >>.
The first method called the image attribute method is simplest way to quickly add an image with text wrap.
First you will need to decide on the location you want the image to appear in proximity to your text content. There are things to consider like the overall image size in relation to the length of a paragraph. In the example I have a short paragraph with small text, so for example purposes I will use an image to match the scale of this example. I have decided to place the image (at the beginning of the paragraph) -- the red X shows where I initially placed the image but I used theimage attribute called align to make the image appear to the right. See example 1
Example 1: Image Attribute Method
TIP: You can create your images with a 5 pixel border matching the page background to provide more predictable spacing between images and text or use the table alignment method explained below. The code used to make this alignment happen was:
<img src="panda.gif" width="80" height="80" align="right">
You could also use the following depending on where you want images placed in relation to text. Here are other alignment options:
align="left"
align="right"
align="top"
align="middle"
align="bottom"
align="baseline"
align="texttop"
align="absmiddle"
align="absbottom"
TDepending on the way text flows you may decide that you want a less crowded look or you might want to add a caption above and/or below the image. This can be achieved with thetable alignment method. The steps for the table method are listed below.
The table alignment method contains the image inside its own table at a set width that is the same as the image. The table as a whole is then set to align to the right as the example shows and given some cell padding for a defined border area. The cell padding is key to this approach and gives you flexibiity to create any spacing between text and images you want. The example HTML code is below using cell padding of "5" and table alignment to the right:
<table width="80" border="0" align="right" cellpadding="5" cellspacing="0">
<tr>
<td align="center" valign="top">Caption Area<br>
<img src="images1/panda.gif" width="80" height="80"><br>
Caption Area</td>
</tr>
</table>
Using this method allows you to also add a caption top and/or bottom of the image if you like.
TIP: Don't forget to add ALT attributes to your images! images provide little use to people with text/speech browsers, browsers with images turned off, and can benefit you from the perspective of keyword density for search engine optimization. Make your images useful to all of your visitors by describing the specific purpose inside the ALT attribute.
Another method: Wrap Text Around images Using CSS >>
click the link for more help.
http://psptips.com/4/web/add2page.html thanks.keep updated.
Posted on Sep 08, 2009
    President:
  • 1,314 Answers
Since you already have it in word, have you tried to save as a works file?
Posted on Sep 05, 2009
    President:
  • 1,564 Answers
In the tools menu there should be a section dedicated to labels. Go to the page set-up and you'll find it there. Most of the options are from the Avery company. You can purchase name badge stationary at your local Staples or Office depot. When you bring it home look for the Avery standard guide number. XP has all these listed in the Works program under the "Programs" page scroll down to mailing labels and that will bring you to the Avery lists. Make sure to indicate that they will be individual lable not all the same,"unless" you want to hand write in the names later. That's it. Good luck. Dana
Posted on Sep 04, 2009
What operating system do I need, so that when I run my cursor along the menu bar a window pops up, rather than a small text box?
How do I get the Aero desktop experience? The following editions of Windows 7 include Aero:
  • Windows 7 Enterprise
  • Windows 7 Home Premium
  • Windows 7 Professional
  • Windows 7 Ultimate
Aero is not included in Windows 7 Home Basic or Windows 7 Starter. You can find out which edition of Windows 7 you have on your computer by opening System in Control Panel.
The edition of Windows 7 you're running is displayed under Windows edition near the top of the window.
You also need to use a Windows theme to display Aero graphics. If you are using an Ease of Access theme, some elements such as transparency and thumbnail previews will not appear. To view which theme you are using, open Personalization in Control Panel.
The theme currently in use is highlighted.
Dec 11, 2014 | Microsoft Windows XP Professional for PC
I cannot open the file downloaded from Microsoft to enable me to use the help file. I am trying to find the meaning of the symbol (underline circle) appearing in text as a superscript. This is in...
I Think Your problem no in QuickVerse 8 Deluxe, but on Windows 7.
1. Software for XP, few can installed on Windows 7 -> i think you use Application for XP
2. Usually windows 7 must be Pacht-ing for use windows XP Application
3. May be you can Try install -> on software -> Right Click -> Run As Administrator "you Must enable Administrator befor".
Feb 19, 2011 | IMSI QuickVerse 8 Deluxe (QUICKVERS8E) for...
I imported text from A Microsoft Word File in to Corel draw and saved the file, when i reopened thecorel file the fonts had all changed and it would not allow me to use the fonts I have used earlier in the...
1.) Did you paste the fonts into a text box in Corel? Sometimes this works better than importing.
2.) try to copy all of the text from Word and then paste into a text box in Corel
3.)Make sure you answer yes to the "maintain fonts and formatting" question when pasting text into text box in Corel
4.) After pasting text, Save the Corel file!
Jan 24, 2011 | Corel Draw 8
Can you put American greeting 8 on to windows 7 ?
The website / Microsoft site does not have any information if this software will work with Windows 7 / Vista, hence it would be a better idea to try installing it and see it it works. If it does not work with windows 7, windows 7 has a very good feature called XP mode to use old software and hardware which are compatible with XP but not with windows 7.
Please check the link below for details of what is XP mode in Windows 7
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=American%20Greetings%20Creatacard%20Platinum&v=Encore&uid=8&l=en&pf=0&pi=0&s=american%20greeting&os=32-bit
Please check the link below for details of how to use XP mode in Windows 7
http://windows.microsoft.com/en-IN/windows7/install-and-use-windows-xp-mode-in-windows-7
Dec 30, 2010 | Broderbund American Greetings Creatacard...
I am trying to download a purchased version of Microsoft office home and student 2007 onto my laptop - Windows 7 64bit (i think) - it "configures" for several minutes, then comes up with "done" but...
Genuine Licensed Product Key Code for Microsoft Office Home and Student 2007. Has your trial version expired? This is what you need to get back up and running. You will be sent electronically (via email) a product key that will convert the trial version of Microsoft Office into a Full Version* Need it immediately call us 877-676-4464
  • Office Home and Student 2007 includes Word, Excel, PowerPoint and OneNote
  • Find and use features more easily: commands are organized in a set of easy-to-browse tabs that more directly correspond to things you do most
  • Find and apply formatting changes more easily with the new formatting galleries with live previewing
  • Create high-quality documents that contain appealing graphics and charts using the new graphics, text tools, and formatting galleries
  • Preview changes fast while you're working without having to repeatedly search through layers of menus
  • Give your work a professional look with the design and typography tools, including 3-D effects, shadows, glows, blurs, and a gallery of chart and diagram types
  • Maintain consistency across applications: ensure consistent-looking tables and text across Word Excel, and PowerPoint
  • Automatically recover and repair documents in the unlikely event of a system crash
  • Share documents with greater peace of mind: detect and remove unwanted comments, hidden text, and personally identifiable information with the Document Inspector
  • Get help via more direct links to Help content than ever before; take advantage of close coordination between Help in the program and Help available on the Internet (when connected)
  • Reduce your learning curve with the improved getting started experience featuring on-line tutorials
  • Compatibility:Windows 7, Vista, Windows XP SP2, Windows Server 2003 SP1
Included:
One Microsoft Office Home and Student 2007 with COA Download only via email*, 1 Purchase Per Household.
*Your keycode email will be sent typically within 3-4 hours Monday - Friday 9-5 EST. If faster service is needed please call for immediate delivery.
Oct 19, 2010 | Microsoft Computers & Internet
I have problems with playing warcraft in windows 7 home premium., in xp, everything was fine, but in w7, it is slow.,thanks !!
it is because xp is old system & it uses less RAM & graphics But the win7 provide good graphics therefore it consumes lot of RAM & graphics so the game works slow
Feb 21, 2010 | Microsoft Windows Vista Home Premium...
Hey i trying to activate my windows product key and when i put my key code in it wont accept them wat can i do to get it working
Click on Start and then Run.
In the text box in the Run window, type regeditand click OK.
Locate the HKEY_LOCAL_MACHINE folder underMy Computer and click on the (+) sign next the folder name to expand the folder.
Continue to expand folders until HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\Current Version\WPAEvents registry key.
Click on the WPAEvents folder.
In the results that appear in the window on the right, locate OOBETimer.
Right-click on the OOBETimer entry and choose Modify from the resulting menu.
Change at least one digit in the Value data text box and click OK. This will deactivateWindows XP.Feel free to close Registry Editor at this point.
In the text box in the Run window, type the following command and click OK.
%systemroot%\system32\oobe\msoobe.exe /a
When the Let's activate Windows window appears, choose Yes, I want to telephone a customer service representative to activate Windows and then click Next.
Click the Change Product Key button at the bottom of the window.Don't worry about filling anything out on this screen.
Type your new, valid Windows XP product key in the New key: text boxes and then click the Update button.
reactivate Windows XP by following the instructions on the Activate Windows by phone window which you should now be seeing or via the Internet by clicking the Back button and following the instructions on that screen.
"Windows is already activated. Click OK to exit."
Nov 02, 2009 | Microsoft Windows XP Home Edition
How do you type inside a microsoft powerpoint slide?
default.aspx?assetid=za790050001033Show All default.aspx?assetid=za790050011033Hide AllDo one of the following:
default.aspx?assetid=za790050011033Add body or title text
Note If your text exceeds the size of the placeholder, Microsoft PowerPoint reduces the font size and line spacing incrementally as you type, to make the text fit.
default.aspx?assetid=za790050011033Add text to an AutoShape
Note To add text to a line, connector, or freeform (freeform: Any shape you draw by using the Curve, Freeform, and Scribble tools. Freeform shapes can include straight lines and freehand curves. They can be drawn opened or closed and can be edited.) AutoShape, you must add text using a text box.
default.aspx?assetid=za790050011033Add text to a text box
  1. On the Drawing toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Text Box default.aspx?assetid=za060447551033.
  2. Do one of the following: default.aspx?assetid=za790050011033Add text that stays on a single line
    default.aspx?assetid=za790050011033Add text that wraps
    I hope this helps
Oct 27, 2009 | Microsoft Windows Vista Home Premium with...
Microsoft Works WP on Vista no longer lets me paste text
Try running the setup in compatibility mode. Here's a link:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/
It may work with the default compatibility mode options, but if not, try tweaking the settings.
May 01, 2009 | Microsoft Works 8 Full Version Mini Box...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
