Question about Brother MFC-8860DN All-In-One Laser Printer
Brother printer mfc 8860dn the screen say's 'drum
Brother printer mfc 8860dm the screen say's 'drum near end' how do we fix that?
8860dm how do i replace laser
HI RSHC,
Please watch this video
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 01, 2014 | Brother MFC-8860DN Printer
How to Reset the page drum count on Brother MFC-8860DN
Open door
remove drum and toner unit
remove toner from drum push on blue tab on side to release
reinsert new toner in drum
reinsert unit in machine
leave door open
hit clear/back on panel --- says new drum-- hit yes
says accepted
close door
Dec 11, 2012 | Brother MFC-8860DN Printer
MY BROTHER MFC-8860DN IS LEAVING "GLOBS" OF TONER ON THE SHEET WHEN IT PRINTS. CAN THAT BE FIXED?
Hello. this error is caused by the "drum". the drum can be replaced either through Brother or your local office supplies store.
There is no quick fix for this issue.
Regards GM
May 30, 2011 | Brother MFC-8860DN Printer
Drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Apr 19, 2010 | Brother MFC-8860DN Printer
Copies are spotty black-need to replace the drum?
Go to reports and print any report, if it looks OK then you just need to clean the glass to improve copy quality. Usually it tells you when the drum is near the end of life.
Jan 05, 2010 | Brother MFC-8860DN Printer
Looking for corona wife for brother 8860dn MFD.
Try to get some corona wire stock which was quite common back in the day and install it in your drum.
Aug 14, 2009 | Brother MFC-8860DN Printer
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
MFC-8860DN
This is a common issue.
Here is the solution:
Pull out the paper tray
On the left of the feed roller there is a black piece of plastic that is a sensor. It is jammed forward. Gently bend it out to the left and push it back until it snaps back into place.
Be careful not to break it.
Oct 27, 2008 | Brother MFC-8860DN All-In-One Laser...
Reset drum - brother mfc-8860dn
Open front cover
Press Clear/Back
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother MFC-8860DN All-In-One Laser Printer Logo
508 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
