Question about Dryers
I have a CRER5700ASO dryer that has a 3 prong plug that needs to be hooked into a 4 prong outlet. How do I connect the 4 prong plug to the dryer? Thanks
  • 30 Answers
Red to Red(left or right side)
Black to Black(left or right side)
White to White(middle)
Green to either white or any ground screw around the terminal block area.
Posted on Sep 04, 2009
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Brand new dryer threw braker twice, then no heat and timer stopped working. Electrician tightened connections on wires to dryer settings dial, had heat for one load, then same as before. Replacement dryer...
might want to check your dryer outlet. If the terminals are loose in there it could cause you problems. If your dryer plug is a 4 prong you might be loosing one of your 220v legs due to a short . As the dryer runs the wires and connections will heat up and expand , if there is a faulty wire or connection then it may loose connection after a load. could be quite dangerous and a very possible fire risk so i would check it out ASAP . if the outlet is old they sell for about $20 at you local home depot or lowes home improvement. for a 3 prong plug you need to hook up the black and white wires on the brass screws and the copper ground wire to the green screw. in a 4 prong application you hook up the black and red wires to the brass screws, the whit wire t the silver screw and the copper ground wire to the green screw .
If your new dryer is supposed to be a 4 prong plug and you have it with a 3 prong cord then you will run in to issues . The difference being a 4 prong electric dryer is a dual voltage unit where it needs both 220v and 115v to operate correctly, where a 3 prong dryer only has 220v and the earth ground. if your not familiar or comfortable with electricity please call a qualified electrician to come hand handle the work. if not done correctly it can cause fires or possible electrocution
Oct 30, 2009 | Amana NED5500TQ Electric Dryer
I bought a roper with a 3 prong but i need a 4 prong. i bought a 4 prong plug but I don't know where to connect the left over wire in the dryer.
The laws in most states are changing to where the NEC Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
So what you have is a red, black, white and green wire on the dryer side of this wire plug.
The red and the black wires are your hots (110 volts) and shall be connected on each outside screw of the drier electrical terminal and the white wire (neutral) shall be connected to the center screw.
So now you are left with an extra green wire with no place to hook it huh?
I suggest just loosing one of the drier electrical terminal mounting screws and hooking it there. The ideal here is to ground the outside body of this machine to prevent possibility of electrical shock if water is present (like a leak somewhere nearby).
In actuality this really serves no viable purpose because the white wire does exacly the same thing, just in a different manor,,, but hey,,, our law makers are not certified electricians either. They just like new ways of stimulating sales and profits.
Note: if you are in a rental property and this 4 prong wall receptical is installed, I would not suggest you remove it or change it in any manor, as this will open yourself up to possibile legal liabilities if an incident were to occur,, like fire.
Oct 09, 2009 | Roper REX4634KQ Electric Dryer
I have a Maytag dryer with a 3-prong plug. My new
The following link explains how to convert a 3-prong cord to a 4-prong:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (WHITE) and Ground (GREEN or BARE) wires are installed. In a 4-wire configuration, the neutral and ground are INDEPENDENT of each other and are not connected together.
Read through the link and let me know if you have questions. I hope this helps you.
Sep 02, 2009 | Dryers
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
