Question about Poulan Garden
My trimmer has a slow start and once it does start, it's not running up to full power and it eventually cuts off.
  • 1,040 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
  • Jim Parker
    Jim Parker Nov 30, 2009
    Did this solve the problem?
    Jim
Trimmer runs but will not cut?
Is this gas or electric?
Sometimes if the trimmer cord is too long, the engine does not have enough power to spin it fast enough to allow it to cut.
Mar 19, 2015 | Garden
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
Starts but cuts off when engine gets hot
when it first dies check for spark or even better get a inline spark tester
Apr 06, 2012 | Garden
Strimmer starts and runs but cuts out when at full power
Easiest place to look first would be to see if one of the fuel hoses has split. May be hard to see but that would cause it to **** air instead of fuel. Eventually, the split or hole would become so big that it wouldn't stay running at all, and probably not even start. If that doesn't do it, make sure the fuel you have is still good and try running a little Seafoam with the fuel and see if it clears up. After that, I would be looking at carefully cleaning the carburetor which may require dis-assembly as well as new gaskets etc.
Jun 21, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Whilst cutting my hedge, inadvertently, I allowed my trimmer to run out of fuel. I refilled it and when I tried to start it, the engine spluttered then stopped and I have been unable, susequently, to start...
The fuel line probably has become air locked .Keep pressing the primer bulb if the trimmer has one and also repeatedly try to pull start the machine with the choke on. Eventually the air should be flushed from the line.
Sep 16, 2010 | Ryobi Garden
My whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Mar 01, 2010 | Garden
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
37 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
