Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Refrigerators my ligt blinks on my icemaker
  • libbi Dec 11, 2007
    Light blinking on the ice maker. No ice is jammed, can get water from dispenser.....
  • 85 Answers
Is the i/m working? do you have the ice bin on the door, if you do the blinking light on the right side of frezzer section is normal
Posted on Dec 14, 2008
The Ice Maker quit. A red light on the freezer wall is blinking.
a steady blink is ok and when you hold the flapper in should be a solid red light. if its blinking and solid when you hold it down the optics are ok. feel the weter fill tube going into the icemaker is it frozen it should be soft. if its frozen thaw it with a hair dryer. if thats ok chances are its the icemaker module which is the icemaker motor. hopethis helps...
Jun 07, 2011 | KitchenAid Refrigerators
Refrigerator has stopped making ice and the light is blinking above the ice maker switch. what do i need to do to correct this problem?
My book says that ice cubes may be stuck in the ince maker.
Turn off the icemaker, remove the cubes and turn the icemaker gake on.
Feb 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My ge profile ice machine on off light is blinking and not making
Blinking light indicates a fault with the icemaker. Look for a blockage preventing the ejector from making a complete revolution, such as a cube that was not cleared, or some other mechanical blockage. All other faults are icemaker component, which are not available as separate repair parts, which would require replacement of the entire icemaker assembly. Please don't rate this if you need a new icemaker, as anything less than a Fix-Ya lowers my score. Thanks.
Jan 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker not working, infared sensor is blinking
We had the same problem. There are 2 sensors on either side of the door, the one that is blinking and the receivor on the other side of the ice bucket. We ordered a new sensor from www.appliancepartspros.com -part #4389102. It came in at 2 days and was really easy to fix. Of course, there is a black rubber tube that adds water into the ice maker from the top of the fridge that froze over. Once we defrosted that, our icemaker worked again.
Nov 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker makes ice, but doesn't dump it.
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
Nov 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
113 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
