Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printer is not printing words - Kodak EASYSHARE 5300 All-In-One InkJet Printer
My Brother 2170w will not print from word 2010.
Welcome to FixYa!
If your printer does not print from MS-Word 2010 and prints from another program, most probably the default printer for word is not setup to your printer.
Open the word document you want to print, click on file, print. Select your printer in the Printer selection box.
Click print. Please see image below.
I hope this helps.
Thank you for using FixYa.
Jas247
Apr 07, 2011 | Brother HL-2170W Laser Printer
Can't get it to print landscape in microsoft word
If the printer is set up to over-ride program settings then your Word settings for a landscape print will be ignored. To fix this, go to your Printer Settings (accessible from Word's Print window) and look for a paper settings option that will allow the printer to either use the print settings from Word, or set the printer to always print in landscape. If you go with the second option just remember that next time you want to print portrait pages you'll have to revert this setting from landscape to portrait.
Jan 14, 2011 | Kodak ESP 5 Printer
Dell V305 does not print word documents
In Word, click file/print (not the quick print icon) and in the printer name window make sure that your printer is selected
Nov 11, 2009 | Dell V305w All-In-One R840635AU InkJet...
I cant print word documents. It says printer is
I have encountered this problem, wherein I can print webpages, excel, pdf files, but not in Microsoft Word.
I received error "Windows cannot print due to a problem with the current printer setup".
I got it resolved by following the instructions given by Microsoft: http://support.microsoft.com/kb/826862
Specifically the steps under 'Delete the Word Data key'.
Oct 14, 2009 | Office Equipment & Supplies
Printer prints blank pages from notepad, word, and excel.
Hi tim8094
Obviously there is nothing wrong with the printer, because you are able to print from the Internet.
Before attempting to print from word, excel etc, make sure you have the correct printer selected (check it through FILE MENU -> PRINT ->PROPERTIES)
Do a print test by typing just couple of words -may be in different color-
Best of luck
luciana44
Sep 22, 2009 | Brother MFC 7420 All-In-One Laser Printer
Won't print from word document
Ok, the you likely have a problem with the printer settings inside the word program.
Try instead of using the print button in word, using the file menu then selecting the pirint option. Make sure when the window comes up you have the right printer setup in the drop down box.
All it takes is trying to print once when that printer is off and word can set itself to a different printer.
Chris
May 27, 2009 | Canon MX700 Office All-In-One InkJet...
Brother 2140 Printer Problem
It is most likly not linked to word. Word is likly sending the prints to the wrong, obsloete or wrong copy of the printer.
When printing check to see where the doc is being sent to print.
Then go to printers to see which printer is your 2140 active and ofcourse do a test print. If the test print is good this is the correct link to your printer.
Dec 19, 2008 | Brother HL 2140 Laser Printer
Hp 3915 printer won't print word docs but will print all else
check MS Word's print setup (File -> Print Setup) and make sure it's set to the correct printer.
Nov 20, 2008 | HP Deskjet 3915 InkJet Printer
Won't print from Microsoft Word
same problem...mine will only print out in duplex mode in word.
May 11, 2008 | Canon i860 InkJet Photo Printer
Print from MS Word 03 & e-mail problem
Click this link for updated drivers if you do not already have them.
When you download and install these, if the problem is still there, then you need to go into your printer program and do a printer check and it will print specific characters to show if the printer itself is printing properly.
Apr 22, 2008 | HP LaserJet P2015dn Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
75 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
