Question about Nintendo 64 Console
New, second hand Nintendo 64
I just bought a nintendo 64 off ebay. It came with two cables, one power cable, and the other has an antenna plug, which I have plugged into the TV, and the antenna into that. When I turn the TV on, the AV screens are blue, and the tv channels are fuzzy. As the system came without manuals, I am not sure I have it plugged in right, and really, what channel I should be putting the TV on.
Help me pleaseeee!!!
Thanks Claudia :)
  • claudiap100 Dec 07, 2007
    Thanks Bob from LI,
    The cable from the N64 console is called the Multi out connector, but on the cable that came with my unit, it has a small box setup with an antenna in and out plug. Is this best to go into the TV or the VCR?
Go direct to the TV, Claudia. You should get a pretty good picture from all components. Occasionally, the boxes fail. Radio Shack used to stock replacements.
Posted on Dec 07, 2007
  • 833 Answers
Not sure what you're actually connecting. First, if you have a switch unit, the antenna or your regular cable go into one side and the game in the connects to the TV. If that's not what's going've got to fix that up. Your local electronics store or Radio Shack can help with the right one. Most units use channels 2, 3 or 4 as set on the tv...not a cable box. There may be a small switch with some of those numbers located on the bottom of the unit so that you can switch to a channel not used for broadcast in your area.
Its the actual connector piece. The coaxile connectors (the ones you plug into the antenna port on the tv suck) you need to get a rca connector cable (the one with the red, white, and yellow) yellow is video the mose important one. the red and white doesnt matter if you mix them up
Posted on Dec 16, 2007
I bought a new AV cable for my nintendo 64 off ebay and when i plugged it in the brightness of my games were really bright
Well it could be because HDTV was not made the time N64 cameout so you would have to use a blue plug for it to work instead of the traditional av cables.
Jan 19, 2012 | Nintendo 64 Console
Cant seem to get my nintendo 64 console hooked up..need to hook it up through the vcr
Just follow these steps and you will be playing your Nintendo 64 in no time at all.
  1. Set your Nintendo 64 in it's desired location
  2. Plug the power cord into the back of your console
  3. Plug the other end of the power cord into an electrical outlet
  4. Plug the AV cable into the back of your Nintendo 64 system
  5. On the back of your VCR find 3 cable sockets colored red white and yellow
  6. Plug the the red plug of the AV cable into the red socket
  7. Plug the the white plug of the AV cable into the white socket
  8. Plug the the yellow plug of the AV cable into the yellow socket
  9. Plug your Nintendo 64 controller into the front of your console
  10. Place your game into the game cartage slot
  11. Turn on the Nintendo 64
If you encounter any problems at all feel free to comment on this solution so that I can further assist you.
Jun 13, 2011 | Nintendo Video Game Consoles & Games
A nintendo 64 i bought off ebay came with a cable to the tv aerial socket. i switched it on - no picture. why not?
this can be one of three things try them all. 1 the cable is bad. 2 the system is defective. 3 the tv is not set to the same channel that is on the little box on the cable. hope it helps.
Aug 18, 2009 | Nintendo 64 Console
How do I connect a Nintendo 64 games system to a Hitachi TV?
Hi kdg 1026,
The wire from the Nintendo should have 3 plugs on the end. Yellow, Whit and Red.
OPn the baqck of the TV you have inputs that are color coded, Yellow, White and Red.
Plug the wires into the color coded inputs.
Turn on Nintendo. Press input button on your TV remote until you get the picture.
Let me know if this helps.
Please rate this solution. Lone99star
Jan 27, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
N64 Connections
You will have to buy a new cable... there really isnt a fix for a/v cables. with shipping and handling they are like 6 bucks on ebay... Im sure you can also find them at a local electronics store... maybe not quite as cheap though..... sorry there isnt a fix for this... but this is definately the solution :D ... Good luck :D.... Please rate well! :) if you have anymore questions, feel free to ask!
Dec 28, 2008 | Nintendo 64 Console
Set up of the nintendo 64 console.
There is a big empty space on the back with a small plug on the inside. There should be a "power brick" that slides in there and then plugs into the wall.
Nov 28, 2008 | Nintendo 64 Console
Nintendo 64
I have purchased the av cable you need on ebay. There are plenty of them available, most have pics of the cable. You need a rectanglular plug with three RCA jacks to connect to your tv. Unless you have an older tv, that will only accept the regular tv antenna connector. Then you will need an RF adapter. Have seen these on ebay also.
Hope this helps.
Apr 04, 2008 | Nintendo 64 Console
Used nintendo 64 av issue
cleaning the cartdriges hole or check if properly inserted if nothing happen youre unit have defective.
Mar 26, 2008 | Nintendo 64 Console
Picture and audio for nintendo 64
Does it plug ino the antenna plug or red/white/yellowPlug?
Dec 14, 2007 | Nintendo 64 Console
Nintendo 64 Console Logo
490 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
