Question about IBM ThinkPad G41 Notebook
Fan error on ibm thinkpad
My ibm thinkpad comes on and then immediately shuts down and says Fan Error
    Genius:
  • IBM Master
  • 1,250 Answers
Take it to the technician remove the fan clean the dust then put it again if its not working then change the fan
Posted on Sep 04, 2009
Thinkpad X41 starting two short beeps, fan error and shuts of
The IBM POST code states that after the 2 beeps the screen displays the error.
In the case you have a faulty fan and it needs to be replaced.
Sep 19, 2012 | IBM ThinkPad X41 Notebook
Fan error on my computer
The CPU fan is faulty and the CPU goes into thermal shutdown.
Replace the faulty fan to fix the problem.
Feb 19, 2012 | IBM Lenovo ThinkPad T61 Notebook
The ThinkPad 2647 8MU will not restart. After a screen that shows IBM Thinkpad, then a black screen comes up that says: Error Fan Error Press <F1> to Setup. If I press <F1> it...
Your system fan has died and need to be replaced. You can look in your bios for a setting to ignore fan speeds, you may or may not have one depending on your bios. But be careful, if you can bypass the fan error, you risk causing harm to your computer by overheating the processer.
Feb 17, 2011 | IBM (26P9166) Fan Assembly, Cooling Fan
Ibm thinkpad 2897 fan error then shuts down
replace the fan, bad fan. not an easy job with the thinkpads,hard to get to the fan.cheap fix though.
Oct 13, 2009 | IBM ThinkPad R40 2897 Notebook
Fan error problem
Sounds like the mother board thinks the processor fan isn't running at all, or not fast enough. Can you verify that the fan is running, by sound and the movement of air through the vents? If no fan/air movement then you should address that fan problem that your thinkpad has developed.
In case it's the fan and you decide to crack it open yourself? Let us know?
Sep 12, 2009 | IBM ThinkPad G41 Notebook
My laptop IBM X 61 says fan error at bot up then freezes up
I would say there's an error with your fan. Running a computer without a fan is a very bad idea, so your computer probably shuts down to protect its self. Any problem with the fan is probably mechanical, so it would need to be fixed or replaced before you can use your pc.
Can you hear the fan running when you start up your computer? Does it make any unusual noises (clicking, grinding..)?
Aug 31, 2009 | IBM ThinkPad T30 2366 Notebook
Shuts down on its own......hot air comes out of
This sounds like an overheating problem. Make sure your vents are free of dust & that the fan is spinning. If they are & it is then you might want to either consider upgrading the cpu fan or purchasing a laptop cooling pad to sit it on while working. Hope this helps.
Jun 08, 2009 | IBM ThinkPad R50e Notebook
Fan Error
You may have a faulty fan, check to fan, it should spin freely, if not the fan needs to be replaced. The fan and heatsink assenble may also be clogged with dust, remove the dust and vacuum to clean.
Jun 07, 2009 | IBM ThinkPad R51 Notebook
Thinkpad G41 Fan Error
did you use heat sink silicon, and make sure the bios settings are set to control the fan speed. you may want to get another spu and try that also..
Apr 20, 2009 | IBM ThinkPad G41 Notebook
T30 fan error
Well, the fan is either unplugged from it's socket, froze up, or completely clogged with dust, etc and is giving the bios reason to shut down.
Also tho, tell me, does the time and date keep needing to be reset?
Could be a cmos battery. Some of the older thinkpads were like that, although my T30 has never shown this problem.
Good luck
Oct 15, 2007 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad G41 Notebook Logo
735 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
