Question about Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor
Error code LO 76
Paloma tankless hot water heater
  • 3 Answers
Check control connections and if good contact Rheem at 800-432-8373 for a new control board
Posted on Sep 10, 2009
3 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
SOURCE: Paloma tankless, gas, water heater, error code C7 76
My Paloma tankless water heater had a code of C7 - 76. I called the service center at 866-720-2076 and they stated this code showed a communication error between the Water Heater and the thermostat; they stated it was still under warrantee and they would replace it for free. Also, I found out there was a recall related to the door properly shutting. To make it work while waiting for the repair, I would turn off the thermostat, wait 2-3 minutes, and turn it back on. Usually it would work for enough time to shower.
Posted on Oct 06, 2010
Paloma model no. ptg2-42pvp
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Bad remote control, bad pc board, bad wire between pc board and remote control
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 26, 2014 | Rheem Paloma Tankless Water Heaters...
Error code C4 76
Error 76 is communication fault with remote control, or bad PCB board.
Copy following link for Rheem tankless troubleshoot:
Call Rheem, and they will recommend service technician.
800-432-8373
Make sure your unit is serviced yearly to prevent common error codes. Which defeats the robust $100 expected yearly savings from owning a tankless water heater.
Oct 13, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
Getting a 76 flashing on my Paloma PTG-74XP tankless water heater
Error code 76
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Rheem-Tankless-Fault-codes.pdf
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 30, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
Hi. We have a Paloma Tankless Water Heater model no. PTG-74PVN-1 and we keep getting the error C 7-76 or C 8-76. We cleaned the filter but the problem is not going away. The hot water turns off after a...
Mar 27, 2011 | Rheem Paloma Tankless Water Heaters...
HOW TO FIX ERROR 79 ON THE PALOMA GAS WATER HEATER MODEL PH-241CWH (1)
Use following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot:
http://www.palomastore.com/paloma_error_codes.html
Range of problems can vary from fan motor wiring, to remote control terminals (error 76), to bad remote, to bad circuit board.
1) Replace remote control
2) Read error 76 and 79 shown in link above
3) Contact local service technician
4) Contact Rheem
Add a comment for more free help.
Dec 29, 2010 | Rheem Tankless Hot Water Heater...
My tankless indoor water heater has an error code C4 76
Error code 76 indicates a communication error with the electronic board and the unit. Call Paloma/Rheem with the serial number and model number of your unit and they will, in most cases, send you a new board with instructions on how to easily replace the board.
Tech Support: 800-432-8373.
Nov 21, 2010 | Rheem Paloma Tankless Water Heaters...
My tankless heater will not turn on and the remote
my rheem pronto tankless water heater will not turn on?
Sep 24, 2009 | Rheem Tankless Hot Water Heater...
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Jul 24, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
949 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
