Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Blue shadow hi, i have a blue shawdow on my projection tv... the lettering is constured by a few inches, mainly on the left side of the screen.. is this due to magnetic effects? or is the bulb going out.. if so, how can i fix this?
  • Phil08 Jan 03, 2008
    I have a similar problem with my Hitachi projection HDTV. I have tried magical focus and manual focus. All did not work. Maybe some electronic components are burned. Do I need to replace something inside or do more adjustment? Thanks!
  • dgeorge1964 Mar 11, 2008
    I have a shadow to the right of images and also have red vertical lines across the screen with visible dots of different colors. I have a Panasonic PT-61LCX65 model.
    Genius:
  • 1,030 Answers
Colored shadows indicate to me a convergence or focus issue. convergence issues can occur on one part of screen. and most recognizable around letters. this might could be adjusted by a technician
Posted on Dec 07, 2007
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sharp AQUOS LC-26SH10U 26 inch LCD Television. Video input problems? No audio. I get a picture using RCA cables but nothing using coax cable. Also I have no audio. When I get a picture using the RCA cables...
You need to replace Main Board of TV to fix its issues, click Shop Jimmy to see an image of that board, call Shop Jimmy on 952-881-6492 or 877-881-6492 for main board availability as currently its out of stock.
Thanks.
Jan 17, 2010 | Televison & Video
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony kp53v75 TV with blue convergence off right by half inch
it is a convergence problem u may have 2 replace conv ic's and some resistors
May 11, 2009 | Sony KP-51WS500 51" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
Dark shadow
you have defective horizontal linearity! replace a capacitor 200uf 200volts!
Oct 02, 2007 | Samsung HL-R6168W 61" HDTV
Rca home theatre big screen tv
If it is truly a 52 inch standard projection set (you have it listed under 32V420T which is not a projection TV) and your 3 colors (red, green and blue) are no longer lining up and are all curved on the sides, then it means that your convergence power supply has stopped working. Post the actual model and chassis number and a better description of the picture here and I will be able to assist you further.
Aug 07, 2007 | RCA 32V420T 32" TV
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
