Question about Acer Aspire 1642ZWLMi Notebook
My PC lost its original Windows
I wanted to liberate space in my PC and deleted the operative system, then I installed Windows XP, but no original. After that I could not listen audio.
¿What can I do?. ¿Can I download directly sound driver by Internet? Please help me.
Try to check what brand and model of pc you have, then go to the manufacturer website and look for the same model and try to see the specs of your pc and look for the soundcard brand then the next step is get the brand and model of the soundcard, search the manufacturer website a they have the exact audio driver that fits to your sound card make sure the driver is for winxp.
Posted on Dec 07, 2007
    Problem Solver:
  • 14 Answers
Yes you can get the sound driver from the internet. Acer's website has a driver download section. You just need to put in the model # and download the PDF. That should have a link.
http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
Lost Acer D2D Recovery Partition
hi
thank you for using Fixya
i have lost your recovery then only once solution just you have to run Windows CD and re load your Windows XP then go to Acer Site and Download drivers for your model
you will find drivers from folowing link
http://www.latestdriversupdate.com/driver/41652.html
May 14, 2010 | Acer Aspire 5610-4648 Notebook
Tip
How to Install 2 or more Operating Systems on your Computer
You will need to make sure your hard drive is large enough to accommodate the space requirements of both operating systems, plus enough room to install software and store files for each perating system. Personally, I do not recommend attempting this on drives of less than 50GB with Windows operating systems XP and later. You will first need to optimize the existing installation to reduce and condense your total disk space. To do this you can run the following utilities on your existing installation: create a restore point then, run a registry cleaner (Ccleaner is reliable and free), registry defrag, system cleaner (Trial versions of Yacimsoft Optimizers or Glary Utilities are fully functional free downloads which will give you all the tools needed to achieve these functions), uninstall any program files you do not use . . . then perform a complete disk defrag once all junk files, temp files, old document files etc have been deleted and removed from the recycle bin . . . then reboot the computer.
To perform the disk partition inside Windows XP and later, make sure you are logged on to a user account with full administrator privileges., then click on start and RIGHT click on My Computer (WinXP) or Computer (Vista and 7) on the start menu and select “Manage” this will invoke the “Computer Management Console. In the far left column find and select “Disk Management” This will open the Windows utility to create disk partitions.Your primary Hard Drive will be labeled “Disc 0” and display information about the size of your drive. Newer laptops and desktops may already show multiple partitions setup by the manufacturer which are used to restore your original factory settings – DO NOT DELETE OR TAMPER WITH THESE OR YOU WILL LOSE YOUR ABILITY TO RECOVER YOUR ORIGINAL OPERATING SYSTEM IN THE EVENT YOUR OPERATING SYSTEM BECOMES UNUSABLE.
Find the rectangular section of the Hard Drive Graphic which bears the word BOOT Right click, Select “SHRINK VOLUME”. A new window will appear with minimum number of megabytes the drive can be. You will NOT want to use the minimum number. If you do, you will be creating a partition only big enough to accommodate your current data. There will be little or no room to add additional programs or save files. What you will instead need to do is look at the total capacity, then calculate how much additional space you want to allocate to your original Windows installation with enough remaining space to install the secondary operating system.
Lets pretend the original OS is any flavor of VISTA and you are planning to install Windows XP SP3 on your new partition . Your HDD is 60 GB (this will be shown in MB units which will be a 5 digit number for drives less than 100 GB and a 6 digit number for drives over 100 GB total capacity).
Note: HDD capacity calculations are not exact. Do not be surprised if your 60GB drive actually only shows a “Total Size Before Shrink” of 58777 megabytes or some other number less than 60000 as you might expect. This is an industry norm. The true capacity is rounded up to the nearest GB even though the actual capacity may be slightly less.
In this scenario the Disk Management utility informs you the minimum size you can shrink your Vista volume to is 22497 megabytes. You want more room for downloads and stuff you add later. The total capacity you need for your XP installation and other files you decide will be 20 GB. This leaves approximately 20GB of space you can apply to the Vista partition. Therefore you will enter a number something like 44000 in the Shrink window field labeled: Enter the amount of space to shrink in MB. Now click the “Shrink” button. The operation will take several minutes to complete. Once the Shrink has completed successfully, reboot the system to make sure your original OS is operational and the computer boots without any issue. Then return toDisk Management You shoulod now see your Vista volume and a second area of Unallocated Space.
Right click in the unallocated space, select “New Simple Volume” This will begin the Simple Volume Wizard. Click Next. Use the maximum size indicated & click “Next”
In the next menu select “DO NOT ASSIGN A DRIVE LETTER OR PATH. Format the new partition to NTFS.Click “Finish”
Return to the Disk Management utility & you will see the new partition. When the format is complete, right click on the new partition and select “change drive letter” use the default drive letter suggested.
Insert your XP Installation CD into your DVD/CD and run SETUP within Vista and select the option to install a copy of XP on this machine.Select the empty new partition you created for XP and follow the installation instructions.
Vista Boot Loader will detect the XP installation and prompt at startup which OS you wish to boot. You now have 2 separate options for which operating you want to run on your computer.
DO NOT ATTEMPT TO RUN PROGRAMS INSTALLED ON ONE OS IN THE 2ND OS. YOU WILL NEED TO INSTALL ANY PROGRAMS YOU HAD INSTALLED ON YOUR ORIGINAL OPERATING SYSTEM SEPARATE INSTALLATION IN THE NEW OS. ALWAYS SAVE PROPRIETARY FILES AND BACKUPS TO THE CORRECT PARTITION CONTAINING THE OPERATING SYSTEM WHERE CREATED.
EXCEPTIONS ARE: MOST STANDARD MEDIA AND DOCUMENT FILE FORMATS – mp3, .doc, .pdf, .jpeg etc. These files are universal and can be accessed from either OS by pointing their opening application to their location on any logical drive.
My Next How-To will be PART 2, Installing multiple Operating Systems on a Clean Unformatted Drive.
Please send any feedback or questions to GeekMaker@hotmail.com
Colt Baldwin – FixYa.com Computer Technology Support Expert.
on Apr 10, 2010 | Computers & Internet
My desktop freezes when im running a program most of the time in my windows 7. there is no blue screen or any error. the pc just stops responding the mouse doesnt move. i dont have a choice but to restart...
Windows 7 is a slightly heavy (lighter than vista though) operating system (OS),
so it tends to freeze on computers with low specifications.
You can free up some disk space by deleting the old windows files, thats if you had an OS before Windows 7 previously installed, you can also delete unnecessary files that you dont need.
If your pc has low specs, and you were originally using Windows XP, the best solution would be to go back to Windows XP
Dec 31, 2009 | Intel Motherboard
Sir i want format my pc . what can do?
Put in the disk for the operating system that you are installing and restart the computer,when it says boot from cd press any button and select install,when it displays the partitions Delete all the partitions by following the instructions,Then install to the un-partitioned space you just created and follow the remaining instructions on the screen.
Jul 23, 2009 | Microsoft Windows XP Home Edition for PC
Software
Your system has a hidden partition with Vista and all your drivers on it, you need to decide wether to keep this partition in tact (incase you want to install Vista again) or to delete it and use the whole drives available space making it one partition instead of two.
ONLY delete the recovery partition if you have a copy of windows XP that you OWN. otherwise if you have problems again, you will have to find a disk again.
You will need a copy of windows xp, set the bios to boot to the cd/dvd rom in the BIOS and boot the system with the xp disk, do a full install first delete any partitions (unless you save the hidden partition, then just delete the large partion)
Repartition the empty space , then format the drive, which you will be prompted to do after partitioning, then the cd will install windows. follow the prompts.
Once finished , go here http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
and download the 5 XP drivers for your system, install the chipset andcpu driver , then proceed to the NIC, audio and video.
You will then need to install any programs you had installed before. keep in mind a vista version of software may not operate correctly on XP. windows xp is about 130 dollars for the disk , but you can find copys on ebay for around 90.
poast again if you need more help
Regards..
Apr 06, 2009 | Acer Aspire™ T180 PC Desktop
Deleting "Windows old " inVista Home Basic
You cannot delete windows just like this.You will have to use windows xp cd.and after booting from cd you will have to format the disk and install xp again.one more thing you should not delete any windows xp system files to create space.
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
Recovery partitions
You' want to set aside some space where to create these backups, they are generally 25% of the total drive space.
the assumption is that there is no data on the drive to save. During the install it will ask where you want to install windows, if there are existing partitions delete them all. Then create one partition and specify it to be 75% of the drive (or whatever you prefer). Leave the rest unpartitioned.
Select the partition you created to install windows on.
Once you have installed windows and all the drivers etc, format the rest of the drive in Disk management (part of Computer management in Control Panel). Finally install your favourite software to create backup restore images, and set it to save on the partition you created.
NOTE: you will still need to back up on some external media, if the drive fails all data will be lost.
Hope this helps
Feb 01, 2009 | Microsoft Windows XP Professional
Trying to restore XP back to Factory Status. Have Trojan Horse (placed in 'Chest)'. No Documentation CD but have all nec specs. What to do with Restore Disc? Have Operating System CD. Ta!
If u want it to factory status then u need to reformat
Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup boot disk into the floppy drive disc if you are starting from Setup boot disks, and then restart the computer.
NOTE: To start your computerfrom the Windows XP CD-ROM or from the Setup boot disk, your computer must be configured to start from the CD-ROM drive or DVD-ROM drive or the floppy disk drive.
In some cases, you may have to modify your computer's BIOS settings to do this.
(If you are starting from the Windows XP Setup boot disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after inserting each disk.)
At the Welcome to Setup page, press ENTER to continue.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. Press ESC (do not repair).
All existing partitions and unpartitioned spaces are listed for each physical hard disk. Use the arrow keys to select the partition or space where you want to create a new partition, and then press D to delete an existing partition or press C to create a new partition using unpartitioned space.
If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this process for each of the existing partitions that you want to use for the new partition.
When all the partitions are deleted, you can then select the resulting unpartitioned space and then press C to create the new partition.
Type the size (in megabytes, or MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition using the maximum size.
If you want to install Windows XP, use the arrow keys to select the partition you want to install Windows XP on, and then press ENTER.
Select the format option that you want to use for the partition, and then press ENTER. The options are:
  • Format the partition by using the NTFS file system (Quick)
  • Format the partition by using the FAT file system (Quick)
You may also see:
  • Leave the current file system intact (no changes)
Most people will want to choose: "Format the partition by using the NTFS file system".
After Setup formats the partition, follow the on-screen instructions to continue Setup until Windows XP fully installs.
Oct 18, 2008 | HP Computers & Internet
My PC lost its original Windows and sound driver
Dec 07, 2007 | Acer Aspire 1642ZWLMi Notebook
Acer Aspire 1642ZWLMi Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
