Red blinking light,no picture turns it self off mitsubishi wd577
  • 556 Answers
Look where the red blinking light is it should tell you what it is for probably lamp, this means your lamp has gone out and needs to be replaced it is a consumer replacable item.
Posted on Sep 04, 2009
Red status light is on but not blinking and picture wont show at all???
access the self diagnosis feature by pressing the menu and device/input buttons on the tv both together and hold them for 6 seconds then counr the teo digit blink code.
Mar 11, 2013 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi TV power light comes for about 12 seconds, without any picture, and turns off.
Try the self check when power light goes off, on front press and hold both the menu and input buttons for at least 5 seconds and let both go.
Power light will blink a two digit error code like 2 blinks,2blinks, pause and repeat it several times.
What error code do you find?
SD TECH
Oct 18, 2011 | Mitsubishi VS-55609 55" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubushi wd 52525 No picture, no sound. Self Dia shows 1.2
No trouble code is 12, is that what your getting? Is red light on all the time or blinking?
Jan 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Rca 52" problem
If you are saying the picture comes on red and then the tv turns off?
I would suspect the video ic on the red picture tube pc board has shorted out.
This is a pretty common problem
Apr 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Mitsubishi wd-62327 red light
1. Self-diagnosis error 4-4, check for open F9A06 part # 283P128050 on the Power PCB. 2. Self-diagnosis error 4-4, check for proper seating of the DVI cable between the FMT PCB and the DMD (Light Engine). It may be necessary to disconnect and reconnect this cable to insure proper connection. 3. Self-diagnosis error 4-4, if F9A06 is good and the connection on the DVI cable between the FMT PCB and DMD are secure, suspect the Light Engine part # 939P977020 4. Self-diagnosis error 4-4, check F9A07 part # 283P128050 on the Power PCB, if open suspect the Light Engine part # 939P977020 5. Self-diagnosis error 4-1, suspect the Power PCB part # 930B929001
Sep 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
232 people viewed this question
Top Televison & Video Experts
Electro Med Services...
