Question about Toto Washlet S400 for Power Gravity Toilets - SW564T694
Continous water running
I have a Toto with the power gravity flush system. I have twisted and pushed the shut-off post down to a lower level so that the water shuts off 1/2 inch from the over-flow pipe, but then very slowly (2 minutes) the water level creaps up and then continuously spills into the over-flow pipe creating a water dripping sound until the toilet is flushed again. It seems like the shut-off valve is leaking a little. Can this be taken apart and cleaned, or do I need to replace it?
  • 49 Answers
Just lower your float a little further. otherwise i'd adsume air is leaking out of your float. but if your float is up in the shut off position and water is still coming out. then you need a new assembly.
Posted on Sep 20, 2009
How do I get the water to stop filling the tank on my toto ST794S toilet?
there should be a screw adjustment on the ballcock or fill assembly...screw that down some to adjust...that regulates your tank water level....that screw goes in or out to adjust...one or other should do the trick...may have to do this a few times to get proper adjustment...good luck..
Jul 07, 2014 | Toto St794s-12 Nexus Tank With G-max...
Our Toto ultramax model MS853113S will constantly
flapper most likely needs to be replaced not sealing completely is one problem----- the other is float level not shutting off water valve --and other is bad water valve not shutting off or worn and needs to be replaced remove cover and turn water on watch water level lift float up if water turns off valve good----turn off water if drain down flapper bad and needs replacement costs a couple of dollars to replace -if water stays level in tank than float needs adjustment or replacement
Aug 01, 2010 | Toto MS853113S#01 UltraMax Round Toilet,...
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
Fluids splash out when flushed
I went through this and called the help line. If the bowl is almost empty after flushing, it may be the water fill line in the fill tank (reservoir on the back of the toilet). There is a small tube that should go into the overflow tube and it adds water to the bowl after flushing. Mine was not attached to the overflow tube when I took it out of the box and the instructions did not mention to check it (or the troubleshooting guide). A picture is worth a thousand words so look for the small white hose going from the fill valve into the overflow tube:_1365.jpg
Nov 17, 2009 | American Standard Cadet 3 Right Height...
New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Sep 14, 2009 | Toto Washlet S400 for Power Gravity...
Toto 1.6 gpf won't stop running
1-check water level make sure it doesnt fill over flush valve.2-check handle make sure its not sticking and chain isnt catching on anything when flushed.3-replace flapper i like KORKY flappers. the red ones. like 6$
Jun 20, 2009 | Washing Machines
Toto toilet Power Gravity intermittently running
You need to either bend the arm that connects tot he float down (if it is the type with the ball float) or adjust the height of the fill valve assembly. THis accomplished by slightly twisting the valve assembly carefully and sliding down a half of an inch or so and then twisting back to lock it in place.
This should fix you up right.
Apr 29, 2009 | Toto Round Carusoe Two Piece Toilet, 1.6...
Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Mar 24, 2009 | Toto Toilet Onepiece Ultramax ...
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Mar 16, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Toto Washlet S400 for Power Gravity Toilets - SW564T694 Logo
1,283 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
