Question about Sony Playstation 3 (PS3) Console
Using Motorola Blue Tooth with PS3
Can I use a Motorola Bluetooth with the PS3? If so, how do I install?
  • Anonymous Jul 02, 2008
    my bluetooth device is registered in my ps3 and i have it connected but when i get online, it will not work
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
In Game XMB:
  • All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
Posted on Feb 18, 2010
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Posted on Dec 07, 2007
2 Suggested Answers
SOURCE: ps3 hooked to my motorola h550 bluetooth
Hold the button for a few seconds and it will connect.
Posted on Jan 11, 2011
How do you connect a motorola H17 to a ps3 slim
Turn on your PS3 and go to settings. Accessories, add blue tooth device, Turn your bluetooth to discovery mode. go back to PS3 to scan mode. Select the H17 that shows up and enter the bluetooth pairing code 0000 that is right four zeros in a row and hit enter on your PS3. They should now synch, the main thing people forget to do is actually select that item inside your PS3 to synch. Hope this helps. Happy Gaming
Feb 04, 2011 | Video Game Consoles & Games
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
Need the code to pair my blue tooth motorola
Try using 0000 as it's the basic code for every bluetooth unless manually change. That is the factory default.
Dec 31, 2009 | Motorola Mobility HS850 Consumer Headset
Loud Noise
IT will give the noise because of the following reasons
  • Due to signal distortion and also that you mieght be useing faulty bluethooth head set .
  • It also occur due to low bettry chargeing
Things to do !
  1. check your blue tooth head set with other Motorola cells
  2. replace your blue tooth head set
  3. clean the connector of the blue tooth cable
Please Rate !
Sep 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
Ps3 hooked to my motorola h550 bluetooth
Mar 31, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Blue tooth is not installing for the ps3
Registering
1) Go to accessory settings
2) Click on Register blue-tooth device
3) Click on Headset
4) Scan, while holding down the main power button on the headset
5) Enter your 4-digit password. The default is normally 0000
6) Done
Using
1) Go to Audio Options (under accessories)
2) Click "Connect Blue-Tooth device"
3) Change everything from "Do Not Use" to your headset name
4) Done..
Mar 31, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do ii turn my bluetooth on!?
go on settings, connectivity and click on blue-tooth on.
Jun 07, 2008 | Motorola Mobility W220 Cellular Phone
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
595 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
