Question about GE MiniCam Pro HO98067 Webcam
GE mini wireless (HO98763) mouse won't work - power light not on.
I purchased A GE mini wireless (HO98763) mouse last week. Installed the batteries, plugged the USB receiver in - everything worked perfectly from the start. Two days later, I noticed my mouse wasn't responding. I found that the LED was no longer red, so assumed that the power was off. Pulling the receiver out for a time and returning it solved the problem for a while. This happened twice. Then the power didn't return at all.
I took this to mean that the batteries had died. Earlier today I purchased replacement batteries and some rechargeable batteries. Neither disposable or rechargeable had any effect. I've tried pressing the connect switch on the USB receiver to no avail. Rebooting hasn't helped.
The rapid loss of functionality resulting in complete inoperability tells me that there may be a short. So it may mean that while I was futzing with the USB reciver, the power came back on its own and the problem has nothing to do with the receiver. There is no on/off switch on this mouse that I can locate.
I'm not an expert and certainly don't think myself to be. Perhaps someone out there can give me a hand? Much appreciated.
    Master:
  • 595 Answers
My advice is to return mouse to store and get a replacement, remember to take bill with you as proof of purchase. If the same fault happens again you could ask for money back. It is technically possible to ask for money back staright away as this rapid falure shows that the itme is "not fit for purpose". Hope this helps.
Posted on Mar 04, 2017
myob247
  • 1342 Answers
SOURCE: Can't find driver
Go HERE
Scroll down to PC Cams
Posted on Jun 03, 2008
yooperbud
  • 8637 Answers
SOURCE: help wit mini cam
Normal 0 Try disconnecting the Camera from the USB port and install the software program you downloaded. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 50 Answers
SOURCE: people cannot see me on cam
every application when it connects to the internet, it uses "ports" , now if the port that the messenger is trying to use for the "cam" is blocked , you basically experience that kinda problem. first disable your firewall (try windows first, then any other firewall (like norton, mcafee or other), also check with your Router or Modem (if DSL) but usually these ports are open by default, but you never know sometimes untill you check it. but your best bet is the firewall that is blocking your port for the cam.
disabling the firewall is the easy solutions, opening the ports is the longer one. of help on opening ports on you DSL modem OR router (or both), check this site
good luck
Posted on Jun 18, 2009
  • 3005 Answers
SOURCE: well i just bought the ge minicam pro ho98067.the mic doesnt work
You do not say what your OS is and if the minicam has a built in mic or what program you want to chat in
This is how I set my mic up with Yahoo Messenger X Vista Home Premium
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
CONFIGURE TO MESSENGER Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK Click ( > ) Messenger > Preferences > Calling and Audio Set mic and speakers to show Default equipment Run call up assistant to test audio equipment > Apply > OK
WINDOWS LIVE MESSENGER
> Show menu > tools > audio and video set up - set mic as default -check settings > Next > set webcam as default - check settings > FINISH
Posted on Aug 17, 2009
  • 4 Answers
SOURCE: GE Mini Wireless Optical Mouse HO98763
Did you try pushing the link button on the bottom of the mouse (right after pushing the connect switch on the receiver?)
Posted on Jan 20, 2010
No red light on mouse...power light on then off again
Wireless mouses never made much sense to me since you have to be right at the computer to use them. I've had so many repair visits when the battery is dead just when you need it most to work. Save yourself the trouble and buy wired mouse.
Mar 07, 2018 | Dell Wireless Keyboard Optical Mouse w0147
I have hooked up a GE 98548 wireless mini optical mouse. It worked the first time I tried it, but later would not work at all. What's next?
on the receiver there is a a little circle with the words connect around it. Its actually a button you press that and you should see the receiver should light up make sure the receiver is connected the computer and press down right on the circle. after it lights up press connect button on the mouse and it should start working again
Jul 02, 2010 | GE Wireless Optical Mouse
Optical wireless mini mouse 98763 feature #9 is
I had all the same problems listed in fixit and found that all it took was placing all NEW batteries in the mouse.
Press the blue light button on the USB and the little black reset button on the bottom of the mouse at the same time. Worked good from there on.
Feb 23, 2010 | GE Wireless Optical Mouse
Both lights are on and working, new batteries, not sure why mouse wont work
try a plugging into another usb port-it should say driver found if you installed software first
Oct 19, 2009 | GE Wireless Optical Mini Mouse 3087897985
Sep 03, 2009 | GE Wireless Optical Mini Mouse 3087897985
GE wireless optical mouse #98763 worked for 2 weeks then.........
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Jul 19, 2009 | GE Optical Mini Wireless Mouse 98793
GE MiniCam Pro HO98067 Webcam Logo
145 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
