Question about Garden
I need to know what type of spark plug I need as I don't have one as I moved country and spark plug didn't come with me!
  • roundo4 May 11, 2010
    Send what brand of mower with the model number and what kind of motor it is with the model, type and code. The mower model number is usually on a sticker on the deck somewhere. The info for the motor is stamped on the engine shroud. In the future add this info when asking for help because then we know what we are looking at and can get you the help faster. Thanks roundo4
    Send me the name brand of mower and model number for the mower. There should be a sticker with this info. Also on the engine shroud { covers the motor and has the pull rope comming out} there should be some numbers stamped into it. They will be model, type and code. Also what is the motor brand Briggs and Stratton or Tech. Send all this info and I'll get back to you. In the future you need to list more info on what we are working with. It makes it easier and faster to get you some info. \ Thanks and good luck roundo4
  • 279 Answers
Go to the local auto parts store and tell them what you have. They can and will help.
Posted on Sep 04, 2009
I just changed the spark plugs & wires on my 95
Oil change 5W/30 and Wynn's thin oil in crankcase . One bottle injector cleaner .to Gas tank .
Jan 23, 2013 | Cars & Trucks
2007 chrysler town & country has a rough idle but drives smooth what could it be
If it idles rough it runs rough,you just don't
notice it
You can start anywhere you want
If you haven't changed spark plugs in 3 years do that
Replace any front or upstream O2 Sensors over 100,000 miles
Check fuel pressure,tps sensor voltages,check for loose air
filter cover,vacuum leaks,loose O2 sensor,just go thru the
entire engine,it obviously needs work & I will bet it hasn't seen
much & you don't know what is done when you ask & pay
for work.
May sound harsh but many shops aren't there to resolve problems,
they throw on as many parts as the people on this site do at home,
from the questions is see here,dealers guess as well and don't road
test,kind of sad really
Nov 13, 2012 | 2005 Chrysler Town & Country
How do i know i need a whole new fuse box
You don't mention the year, make and model of the vehicle so, my answer will be as vague as your question.
A gasoline engine needs four things to run: fuel, spark,compression and combustion.
When you turn the key does the starter engage? If no, check for power at both sides of the fuse when turning the key.. If there is no power at the fuse when turning the key, go to the ignition switch. You have isolated your problem.
If there is power at fuse then, go to the starter relay. If there is power going into and, going out of the relay then, check the starter. You have isolated your problem.
If yes, check for fuel, spark (plugs and wires), compression(block, pistons, rods, Intake and gaskets) and combustion (small scale explosion from compressed fuel and spark, thus pushing piston).
Your problem may be with a passive anti-theft system installed by the manufacturer. I wouldn't know because you didn't mention the year, make and model of the vehicle.
Your problem could be with a collision based fuel shut down system installed by the manufacturer but, I wouldn't know because you didn't mention the year, make and model of the vehicle.
Your problem could be with any number of common issues related to a specific vehicle; issues that may been discussed at length on this very site but, I wouldn't know because you didn't mention the year,make and model of the vehicle.
Oct 25, 2012 | Max American Terminal 30 i Fuses
My 1997 sunfire 2.2L is only running off of two cyclone and it's don't have it's right power and it idles werid ....I changed crank and cam senior...new spark plugs and wire harness but...
Check for spark out of the coil for those two cylinders. If there is no spark swap the coils. If there is still no spark out of the same cl replace it. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 07, 2012 | 1997 Pontiac Sunfire
I need to change my rear spark plugs
  1. Disconnect the negative battery cable. Wait at least 90 seconds before performing any other work.
  2. Remove the ignition coil(s). The Spark Plugs are underneath the Coils
  3. Using a 0.63 inch (16mm) plug wrench, remove the spark plug
  4. CAUTION== Replace your Spark Plugs with the Original Type Plug Brand Name and Spark Plug Number OR you will have Problems with PRE-INGNITION: DON'T SUBSTITUTE to Any other Type Spark Plug. You might have to get them at the Dealer Ship.
Feb 04, 2012 | 2004 Lexus ES 330
Chrysler 2005 radio not working
i am not positive but if he disconnected the battery to perform his task then it may be that you need the code to reset the radio.
Dec 06, 2011 | 2005 Chrysler Town & Country
How do you adjust the rip fence on the Dewalt 744 type 1 table saw
there are 2 bolts on the backside that you need to loosen and move the fence to the blade to align it properly, after aligning tighten the bolts and I always recheck to ensure that it didn't move, there are instructions in the owners manual and if you don't have one you can go to dewaltservicenet.com and download one for the tool. Let me know if you need more assistance
Sep 27, 2011 | Dewalt DW744S 10" Portable Table Saw with...
2 months ago i replaced all the spark plugs and coil packs on my 2003 mazda 6. yesterday my car started acting the same way as when i needed these things replaced and today the check engine light went on...
I don't know how many miles you have on your car, but it is possible that you may have a spark plug being fouled out either with oil or coolant. I had a Protege with 120k and it burned more oil than gas. Change #3 plug and get a good look at the plug you remove. Look for signs of contamination.
Aug 18, 2011 | Mazda MAZDA6 Cars & Trucks
Spark plug location
Hi Sayso
They are hiding below the spark plug coil boxes.
Remove them and there are the spark plugs.
Good Luck.
Don´t forget to give me a FixYa rating please !
John.
Jan 26, 2009 | 2002 Jaguar S-Type
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
