Question about Cycling
I fell on my bike and the handlebars and stuck to the right side.
    Scholar:
  • 104 Answers
Depending on the bike, you will most likely have a nut at the top of handlebar stem or two socket screws at the side of the stem that grip the front fork. In either case you need to loosen them slightly, reposition the handle bars and then tighten up. Quite often however if you stand in front of the bike with your legs on either side of the front wheel and turn the handle bars their is enough slip to move them back. Be carefull you dont strain anything if you dont back the threads off.
Posted on Sep 04, 2009
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Ball bearings fell out of handlebar connection on 3-speed bike.
Take it to a professional bike shop. They have the knowledge and tools to set it right.
Or take a look at this:
http://www.sheldonbrown.com/headsets.html
The headset nuts were not necessary to be moved for handlebar adjustment. Now the bearing load is too tight. Correct adjustment of the headset requires a delicate balance between tightness and freedom of movement. If your bike has/had the original bearings it's a safe bet they may be due for replacement anyway.
Posted on Apr 28, 2010
Can't control the handlebars. They wobble.
IF you are saying the wobble is side to side then the main bolt that goes from the handlebars to the fork is loose.
Aug 29, 2014 | Next Kent La Jolla 24" Girls Cruiser Bike
Gears in front handlebars fell out
Do You mean the GEAR SHIFTER fell apart? There are no gears in the handlebars.
Mar 29, 2013 | Huffy Mens DS-5 Mountain Bike
The handlebars on my daughters Jubilee seem to have fallen downward. She thinks a bolt securing it has fallen out, but it looks to me that if we tightened the middle with an allen wrench it would secure...
There are two sets of bolts here. The first one is straight up and down, is probably the one that takes and Allen wrench and is the one that tightens the handlebar stem - that's the pipe that goes down into the frae toward the front wheel. At the bottom of that bolt (inside the bike frame where you cannot see it) is a wedge-shaped nut that wedges the stem tight. If the stem is loose, then you will be able to stand in front of the bike with the front wheel between your knees and turn the handlebars side to side, and if it is loose enough you will be able to pull the whole stem right out of the bike. On the other hand, maybe you mean that the handlebars twisted down (so that the ends of the handlebars are pointed toward the ground - this would mean that the other bolt or set of bolts are loose. Some bikes have one bolt that clamps the top of the stem around the handlebars, and some have 4 smaller screws that do this. If this is where the problem is, then no, you don't need to buy the Allen wrench, but it sounds like you might need a bolt.
Aug 07, 2012 | Motobecane Jubilee Deluxe
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
Tail light stuck on
You did not say what year or model bike you have but if the brake light is stuck on, you probably have a bad front brake light switch. The switch is located in the right handlebar switch housing and protrudes out so that it is operated by the front brake lever. Make sure that the front brake master cylinder is adjusted down tight against the right handlebar switch housing.
Good Luck
steve
Jul 02, 2011 | Harley Davidson Runner VXR 200 Motorcycles
I dont know how to put the gear switcher back on
The gear switcher (cycling terminology: Shifter) should be attached via a band with a simple bolt through it. The shifter will attach to the handlebar (right side for rear shifter/ left side for front shifter).
coachphil.jpg If you have shifters that are shaped like a barrel as in the picture, then you have to remove the grip on the side you will install the shifter. slide the shifter onto the bar and tighten the set screw in the housing (should be just back of where the cable comes out). Reinstall the grip and there you go.
This is a simple proceedure, however if things are not tightened properly you can get into an accident, for this reason I would recommend taking the bike to a bike shop and having them reinstall the shifter and make sure that everything is safe and functioning properly.
Final Note: If your shifter was on the bike and functioning properly and fell off, then you need to go into a bike shop. The shifter has something broken and either needs to be replaced or fixed. Shifters do not just fall off.
Nov 19, 2010 | Jeep Cycling
Apr 26, 2010 | Huffy Womens Mountain Bike - Passion...
My Motorcycle fell over!
Chances are the forks are just a bit out of alignment from the fall. Put the bike on the center stand with the front wheel pointing perfectly straight ahead. Are the handlebars looking like they are turning a bit to the left or right? If so, just go to the front of the bike and straddle the front wheel while facing the rear of the bike. Hold the wheel firmly with your legs and firmly twist the bars back to a straight position. Re-check the alignment and re-adjust as needed. Now go ride and check it out.
Please rate this solution. Thanks!
Jun 09, 2009 | 2003 Suzuki VL 800 Volusia
Cycling Logo
112 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
