Question about Kodak EasyShare M1033 Digital Camera
Dead Pixels, Shaky Focus (green Square), Poor Photo's in Light and Dark Conditions, Noisier than before, Flickery Screen.
    President:
  • 1,564 Answers
Sounds as though the entire unit is not getting the reqired voltage. You may want to try cleaning the contacts inside the battery compartment with a Q-Tip "dampened not soaked" in rubbing alcohol. Do the same to the battery contacts and the charging stand contacts. At the worst case senario you may need a new battery. Please understand that the battery indicator is not always as accurate as we would expect. Good luck, Dana
Posted on Sep 04, 2009
My brand new LG 37' Led/Lcd t.v. had four very light white spots that you can see in the background what causes this?
Hello
Dead and Stuck Pixels
Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel.
A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background.
A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed.
Hope this helps, if so do rate the solution
Jan 16, 2011 | LG 37LC7D 37 in. LCD HDTV
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Samsung le32r7 2yrs old
Well the shadow is caused by the pixels going dead. There is a term for this "dead pixels" if its still under warrenty take it in. If its not you may be able to get a new screen for it on Ebay.com I use ebay a lot and boy I found thing I though I would never find people are very informative and you will probably need to take the screen you bought to a repair shop and have them place it in for you. this is not a quick fix so I hope this helps.
Apr 23, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
A week ago I purchased a Canon Ixus 970 digital camera. When using in dark conditions yesterday, I noticed two bright blue dots on the LCD screen. I've switched the camara off and on again and have...
You could try taking it back to the store if the (what seems like) the dead pixels are "distracting" you or "annoying" and if you are lucky you might get it exchanged.
It partially depends on the amount of the dead pixels present as for an LCD screen to be classed as being defective 0.01% of all of the pixels on the screen must be "dead".
God luck if you will try to exchange it.
Nov 07, 2008 | Canon Cameras
Toshiba regza lcd 46x3500
This is what is known as a dead pixel. If you have a standard wide screen lcd monitor it has over 1 million pixels. It is not super un-common for one to go bad. It will either always be dark or in your case always be lit. It is not worth it to repair, and in most cases unless you have multiple dead pixels with in a square inch of screen, it is not covered under warranty either.
Each pixel is individual and the problem will most likely not spread.
Jul 08, 2008 | Televison & Video
Samsung digital s73 camera
Hi, there are many reasons why a camera may produce less then sharp pictures.
1) Dirty, oily or damaged lens: Check for dust and fingerprints.
Clean lenses with extreme caution, using dry lens paper.
Use only minimal pressure and gently wipe from the center
outwards, NEVER in circles.
If the lens is really dirty, ask a professional photo dealer to
clean it for you as a free courtesy.
2) Check to see if the auto-focus is working correctly, this could
be an electronic or mechanical problem requiring servicing.
Focus the camera on sharp image at various distances,
to see if it responds by moving the lens.
3) Can you focus the camera manually?
4) Can you focus by moving the camera back and forth
in regards to the object of interest?
5) Is the auto-focus feature somehow disabled in the menus ?
6) Are the batteries up to snuff, they may be strong enough to
turn on the camera, but too weak to move the focus motor.
7) Is the subject you are trying to focus on out of the
focus range of the lens: i.e. too close ?
8) Is the subject you are focusing on too bland, with insufficient
detail to activate and lock the auto-focus.
9) Do you have enough light for the auto-focus to operate.
10) Does the flash unit project an red pattern to help with
focusing.
11) Are you mistaking sharpness (focus) for depth of field.
In low light conditions, the lens iris opens wide, just
like your eye, to let more light in.
This results in a loss of focussed depth of field. This
means that focusing becomes much more sensitive
and critical, such that (when) the main subject is in focus,
everything behind and in front of the subject is not.
This is a theoretical limitation of all optical lenses:
The greater the focal length and the greater the aperture,
the shorter the depth of field.
This can actually be very beneficial when shooting a
portrait: Focus on the eyebrows, blur the background,
or it can be very detrimental: When trying to magnify
a butterfly on a tulip in low light conditions, getting
everything in focus is impossible.
12) Are you mistaking motion blur with lack of focus,
due to slow shutter speeds.
13) Are you shooting in very low light conditions,
causing the picture to become more noisy,
due to the way the digital camera sensor works.
14) I you come up empty on all these suggestions,
you probably have a defective camera and it is
warranty time:
a) Defective electronics
b) Defective auto-focus mechanism
c) Defective lens, loose internal elements
d) Detached sensor chip
.... etc
Try to isolate the problem. Try to manually and
automatically focus on a wide range of subjects,
at various distances, in bright daylight conditions.
If you are still unable to focus the camera,
it is probably defective and requires replacement
or servicing
BTW
Quick review of the internet, indicates that
this particular model is notorious for high battery drain
and battery connection problems. This may be the cause
of poor auto focus as indicated above.
Also this camera has insufficient internal memory, and
and an add-on memory card is required. It is possible
that without the memory card, the camera is defaulting
to a very low pixel resolution, in order to save memory
space, thus creating the appearance of poor focus.
The nominal resolution of the camera = 7.2 Mega Pixels
is respectable for such a low cost camera, but the
reliability reviews are not good.
Martin
Apr 24, 2008 | Samsung Digimax S730 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
