Question about Maytag Dryers
Interior drum one of the three turner shelves fell off into the drum during the cycle - help
    Sergeant:
  • 222 Answers
Unplug the dryer
Unplug the dryer
UNPLUG THE DRYER
remove the top and remove the front panel look for the screw(s) that fell out at the inside under the drum use a flashlight and a magnetic pick up tool screw the baffle back in replace front and top.
Posted on Sep 04, 2009
Indesit WDG1295W. Why doesn't it drain?
The pump and connecting lines could be choked with debris the filter didn't catch.
Dec 26, 2015 | Washing Machines
The freezer still goes but not the fridge part.
You have a unit whose defrost cycle isn't working properly. The defrost element is either controlled by an actual timer motor or it may be controlled by a circuit board. Either the defrost element is defective, the defrost timer is defective or the circuit board is defective. A very remote possibility is the defrost termination thermostat could be 'open'.
If you TOTALLY defrost the freezer compartment, your unit will work decently for about three days until it freezes solid again. The evaporator coil in the freezer is covered by the interior and inaccessible without removing the freezer shelving and the rear of the freezer interior. If the element is defective, it is located behind this cover and is imbedded within the evaporator coil itself.
Feb 20, 2015 | Refrigerators
My admiral washer ATW4475TQ0 makes a thumping noise at end of spin cycle and when lid is opened during spin. What could be wrong?
there are stabilizers on the drum if they have fell off or broken away the drum will swing wildly around on spin this will cause the drum to "hit" the inside of the washer,,,check the drum stabilizers are in good order
Aug 08, 2010 | Maytag Washing Machines
Towels smell sour. while cleaning noticed small "hole" (factory made) in bottom of boot in front of three "notches". seems like a drain hole? stuck q-tip in there and stinky black muck discovered. ran...
I think you are talking about the door gasket. Use a mixture of bleach and water in the gasket and also in the drum. Most front load washer are notorious for mold and mildew. Run the washer in a rinse cyle to clean drum. Also clean your drain filter.
Jan 06, 2010 | LG WM2688H Front Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Oven shelve falls
You are right, this is very dangerous. It is possible that your oven walls expanded, but honestly, I've never heard of this before, but this is what it sounds like!! I would call Sears right away and have them come out and check it. If the walls did expand, you have a defective oven and they should recall that model. I'd really love to hear the outcome of this complaint, so please let me know how everything turns out for you. And you better get it repaired before Thanksgiving. Have a great day!
Sep 07, 2009 | Ovens
Fwt449gfs1 unbalanced in spin cycle
there is a three post bracket bolted to the back of the inside drum. on ours two of the three spokes are broken. looks like you have to buy whole new drum assembly. around 300 bucks
May 21, 2008 | Frigidaire FWT449
Dryers Logo
67 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
