Question about FrancisFrancis! X3 Espresso Machine
Needing a Francis Francis X3 portafilter and steam head
Hi there - I recently inherited a FF! X3 that needed some cleaning but is now pushing water and steam fairly well, but now I need a portafilter so I can make some espressos! Anyone know of a place apart from Illy that I can find one?
Thanks and Best Regards,
Matt
    Problem Solver:
  • 5 Answers
If you have no luck finding a FF! portafilter, you can use the ones from some Ascaso models. See http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html for more details.
Posted on Nov 06, 2009
I descaled my machine and then cleaned the porta filter. When I remived the portat filter another internal screw came out. When I put them both back in tight I get water or steam leaking out of the porta...
If what you are calling the portafilter is actually the shower filter,( portafilter is what you put the coffee in, shower filter is the one in the group head which is held in by a single screw) then when that second screw fell out it sounds like one or two other things may have fallen out also. To stop water/ steam leaking out the boiler, a small rubber seal and spring seat up in the hole where the water comes out. You need to find them or get new items and fit them to the machine. If not sure, get a parts diagram and you will see what I mean. They are easy to replace.
Dec 15, 2010 | Saeco VIA Venezia
No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
Dec 03, 2009 | Saeco VIA Venezia
I need a Francis Francis x3 portafilter for ground coffee
If you have an X3 Trio - you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Oct 09, 2009 | FrancisFrancis! X3 Espresso Machine
Need an FF! X3 portafilter - anyone have one?
If you want to make espresso with loose coffee (as opposed to pods), You will need both a portafilter plus the special tamper. Believe it or not, the tamper comes apart and part of it stays in the portafilter! Sounds strange I know, but it works well. The tamper is bakelite with a metal screen. You will probably have to call Empire Fulfillement 877.854.4141 or ffservice@illyusa.net
Sep 03, 2009 | FrancisFrancis! X1 - Stainless Steel...
Waterflow/heat seems fine - but little/no extraction
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
May 09, 2009 | Rancilio Silvia Espresso Machine
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Saeco Aroma Problems
Whenever we had this problem we needed to prime the pump. Turn the machine on and wait for the coffee light to come on. Then push the coffee button and turn the steamer on wide open until water comes through the coffee outlet. I hope that helps. The user manual can be downloaded from the saeco site.
Sep 26, 2008 | Saeco Aroma Espresso Machine
Francis!Francis!3X overheating
Your thermostat has failed. The middle button is the pump. The bottom button is for the steam mode. If you are getting steam instead of hot water when using the pump, then the boiler is way too hot. Either adjust the thermostat or try descaling the boiler.
Feb 13, 2008 | FrancisFrancis! X3 Espresso Machine
Steam Wand Broken
Something is stuck inside the wand. Get a small pice of wire or small paperclip and inset and try to clear the blockage
Nov 12, 2007 | FrancisFrancis! X3 Espresso Machine
FrancisFrancis! X3 Espresso Machine Logo
819 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
