Question about Bosch WFMC 3200 Front Load Washer
Clothes retain too much water
This is an intermitent times, the washer finishes its work with no error messages but when I open it, the clothes are still very wet. Not sure if it is skipping the spin & drain cycles or doing them but not effectively.
  • Anonymous Dec 23, 2007
    Spin cycle will not start. Have unpluged machine, waited 5 seconds, and repluged, as the manual said.  Still will not spin.
  • Anonymous Dec 27, 2007
    Same problem. Intermitent E04.
    Follewed the directions on the manual cleaning the drain outlet and the
    filter below. So far no success finding the source of the problem.
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 02, 2008
I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
Basic Reset
One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
Feb 26, 2014 | Frigidaire Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
May 27, 2011 | Westinghouse Washing Machines
I have a front loading washer... It it not finishing load. With error message f 02. And clothes is still soaking wet. What is wrong?
Your pump filter screen is probably plugged up.... see link below for a description of how to unclog...
Nov 04, 2010 | Maytag Washing Machines
Olivia just emailed, got charged the $12.95, but did not get her question answered by Charlie. We have Maytag Model MDE 2400AYW clothes washer, and it stopped mid cycle. We can not open the door of the...
the nd error which is showing up in the unit is due to something blocking the motor.mostly its a blockage to the motor and rarely its a faulty can be anything like hairpin,socks,coins any metallic object this has to be checked and reoved the error will go.
washer has a latch and lock on the door. If this lock fails to open when the cycle is finished. You can rescue your clothes by:
1) Remove the bezel from the soap/bleach/fabric softener dispenser.
2) Locate the red cord near the right front corner of the dispenser opening. Pull on this red cord. This will unlatch the door so you can rescue your laundry. Then call for service.
Nov 28, 2009 | Maytag Washing Machines
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
E20 Error Code
Greetings jeanne1568,
Other consumers have reported this error message and found it relates to your "Coin trap assembly" being blocked, therefore not allowing all the water to pump out. The suggestion out there is to remove the front access panel, and remove the clamp that connects this trap assembly to the pump and clean it out.
I hope this helps.
Go Ahead. Use Us.
Jun 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
Close are Too Wet
Are you getting any type of error message on the display?
How long have you had the washer? Have you ever cleaned out the filter?
I also have a Duet (2 years old) and my clothes were not spinning out as well as they once did. I started getting a SUD error message with almost every load and then started getting a F5 message which the manual says it means it's not draining correctly. It never said how to fix it though. Went into the panel underneath washer, found the clean out plug for the was gross! Cleaned it out, washer works like new again.
Feb 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
48 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
