Question about Kenmore Washing Machines
Kenmore Stock#25812 does not stop filling with water. Overflows and creates a flood.
    President:
  • 744 Answers
Hello,Sounds like a problem with either the inlet valve or the pressure switch, The way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch The inlet Valve is located normally on the back of the machine. The pressure switch can be located inside the control panel, It is the part that has the plastic tube attached. You should replace the part that you find to be faulty. If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Posted on Sep 04, 2009
My top loading machine will not stop fill it overflows is there anything I can do to fix it
Does the water come in when the machine is off ? If so, the fill valve is jammed open and needs to be replaced. If the water only floods the machine when the machine is on, it is most likely the preasure tube is blocked or the preasure switch is faulty. Job for an engineer.
Oct 04, 2014 | Washing Machines
I have a Kenmore 90 series washer that overflows. What is happening is that during the initial fill, it shuts off. However, part way through the agitation cycle, it adds more water and would overflow...
In the old days before electronics took over a small bore tube connected the washtub to a pressure switch. As the water level rose a pressure would be created in the washtub and at a predetermined level the pressure switch would cut off the water supply. A blocked tube or a broken pressure switch (or a leaky washtub) would cause flooding. A leaky washtub would prevent the required pressure build up.
I haven't been inside a modern machine so I don't know the arrangement but I expect it is similar - apart from the switching, which will be performed by the computer, digitally of course...
Oct 23, 2017 | Washing Machines
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
All of the water filling my kenmore washer is flooding out bottom
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 15, 2009 | Kenmore HE2 Plus Front Load Washer
Wo'nt stop filling with water and overflows.
If it fills with water while the machine is off replace the water inlet valve.
It is only overfills while machine is on, check the water level switch and the plastic tube going to the water level switch. The tube may be pinched or have a hole it it.
Apr 05, 2009 | Kenmore 23822 Top Load Washer
Kenmore Washing Machine won't drain properly, overflows at PVC pipe. I can run a gardenhose all day long and it won't overflow. But as soon as the Wash Machine Pump starts to empty the basin I can her the...
Check your waste pipe roof vent.
If it is not free (of dead animals leaves etc) - it creates a suction - rather than a drain in your pipe.
Mar 30, 2009 | Kenmore Washing Machines
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
Jan 10, 2009 | Kenmore 16919 Built-in Dishwasher
Ice maker water will not stop/overflows
either u got a bad ice maker or the spout going into the ice maker is leaking, ect.
Aug 24, 2007 | Kenmore 53642 / 53644 Side by Side...
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
