Question about Samsung CLX-3170FN All-In-One Laser Printer
How to clean a samsung clx-3170FN imager
How to clean a samsung clx-3170FN image. I am getting ghost images on my print-outs.
Samsung clx-3160 fn printing ghost images
Remove the fusing unit and clean the upper and lower fuser roller.
Apr 04, 2013 | Samsung CLX-3160 All-In-One Laser Printer
Replaced a new black toner into clx3175fw it prints lines and ghost images how can i rectify that. do i need to clean the head ? please help
Dear
The developer clean blades must be cleaned. Also the ITB cleaning blade to be cleaned. If the waste toner drive shaft broken.
Thanks.
Feb 28, 2012 | Samsung CLX-3175FW Multifunction Laser...
Samsung 3170 reset imaging unit
The drum fills up with waste toner and you can empty it but its messy and you need to clean everything carefully after taking it apart. Take out the imaging unit, unloosen the screws on both sides, unmount the retainer springs and push the center pin out of the drum. Take out the drum and unscrew the two screws that were hidden behind the drum. Now take away all parts so that you can empty the waste drum container. Clean everything especially the light emitting panel, drum and white plastic cover needs to be clean. Hope this helps.
Feb 15, 2012 | Samsung CLX-3170FN All-In-One Laser...
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
Can not find the imaging unit for samsung CLX 3170. Do not know how to fix it. Printer says to to replace it soon.
Please have a look at the links below; each includes a short video to help explain the process. You should order an imaging unit to have on hand for replacement. At the end are included the product number for your consumables. Suggest you find a local supplier or seacrh on-line for a competive price or you can opt to puchase directly from Samsung.
How to replace the imaging unit on CLX-3170FN
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?AT_ID=210811&PROD_ID=1093&PG_ID=-1&PROD_SUB_ID=0
How to redistribute toner
http://www.samsung.com/au/support/howtoguide/supportHowToGuidePopup.do?howto_guide_seq=2632&prd_ia_cd=06010100&map_seq=20418&regDt=20091028182505&page_gb=D&model_name=CLX-3170FN&type_ia_cd=06010000&subtype_ia_cd=06010500&row_index=
What to do when toner is empty on CLX-3170FN
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=41&PG_ID=0&AT_ID=210821&PROD_SUB_ID=0&PROD_ID=1093&EMAIL_ID=41
I could not find information specific to your model on the proper relacements for the imaging unit and toner cartridges; however, I was able to find a statement that the CLX-3170FN and CLX-3175FN are the same printer the main difference is just the colour of the unit. They should therefore use the same imaging unit and toner cartridges which I have listed below:
CLT-M409S Magenta
CLT-C409S Cyan
CLT-K409S Black
CLT-R409 Imaging Unit
CLT-W409 Waste Toner Collector
CLT-Y409S Yellow
Trust this is helpful. Please vote.
Dec 29, 2010 | Samsung CLX-3170FN All-In-One Laser...
Double printing in my samsung 3160 fn
Double printing, such as second "ghost" image has nothing to do with cleaning, but with the drum unit. Print out the System Data Report (Press [MENU] until "System Configuration", then right arrow until "Reports", press [ENTER] and then right arrow until "System Data". Press [ENTER] twice to confirm.
With the report on hand, check the total color prints. If they are near 12,000 pages, change the drum. Be advised, the Image Unit (drum) is an expensive consumable. Part number is CLP-300A.
Be blessed.
Oct 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3170FN All-In-One Laser Printer Logo
1,429 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
