Question about Husqvarna Viking 1
I was cleaning my bobbin case and the cutter and blade came off. Can you send me a picture so I can put it back together?
    Novelist:
  • Husqvarna Expert
  • 371 Answers
I don't think I have a picture but let me see if I can describe it to you.
The metal cutter has a black plastic piece. The blade fits in the black plastic with the longest point on top. The black plastic piece slides back onto the metal cutter, riding on the ridge. Fit the metal cutter back on the unit, being sure to align the "stubs" in the holes of the black pieces attached to the cog wheel. Make sure the "stub" of the black plastic piece with the blade fits in the parallel groove so that only the metal piece moves out and brings the thread to the blade when the cutter is activiated.
If you are still unable to fix, make a comment back and I'll go take pictures of my machine's cutter system.
Good luck.
Posted on Sep 25, 2009
Bobbin thread not cutting
With the bobbin case out of the machine, touch the cutter button. Do you see the cutter arm move from left to right and then back left. If not the cutter arm is out of place. If it does it is something else.
I usually check two things:
1 - your cutter blade might be missing or dull and needs to be replaced. I would not recommend doing this yourself unless you are very good.
2 - many times there is lint or loose threads around the cutter in the area to the left of the needle plate that needs to be cleaned out. You can remove the cover to this area by first removing the needle plate and bobbin case. Then the cover is accessible to pop off by sliding the tip of a small screw driver under the cover at the bottom right corner of the cover. There should be a little opening. Carefully pop the cover off but be careful that the blade mechanism does not come off too. With your finger carefully hold the silver metal blade area steady and pick out the loose threads/lint from around the copper looking metal part. There is velcrow on the tip of the copper metal part so be sure that you don't remove that too. That's what holds the thread for the blade to cut it. If velcrow is missing, or the silver metal part is out of place that could be the problem also.
I recommend that any repairs/service be done by an authorized Viking dealer. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck
May 13, 2014 | Husqvarna Designer I
How to clean wiper sensor on enterprise
Cutter blade needs replacement. Sensor is likely fine and is not located in the bobbin case area.
Sensor is telling you there is a cutter error. More than likely need a new cutter. Easy enough.
Cheers,
Kelly
San Diego, CA
May 09, 2014 | Baby Lock Sewing Machines
I have a Pfaff grand Quilter and my top thread is not catching the bobbin thread. When it does the stitches skips. Can anyone help!?
Hello
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Jul 15, 2011 | Sewing Machines
My singer 4423 is having an issue. the thread from the bobbin is not looping with the thread by the needle. If I feed some material through the needle goes up and down like it is suppossed to but there is...
Hello
Have you replaced the needle? Sometimes something that simple will solve the problem.
To solve the problem i put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
some machines can get "out of time"...the needle and the bobbin thread don't arrive at the right place at the same time.In this case you need to take your machine to a repair shop for re-timing
Jul 14, 2011 | Singer 4423 Sewing Machine
How do I change the cutting blade in my Designer 1 Embroidery Machine?
You need to remove the gray cover next to the needle plate and bobbin cover. First remove the bobbin cover, needle plate, hook cover, and bobbin case. Next, take a small straight slot screw driver, about 3mm wide, and insert it under the gray cover that is just left of the hook area. Pry up the cover just slightly, and at the same time slide the cover towards you. It should just pop off. If you having cutting problems, you should the cutter blade, the cutter holder (black plastic piece), the fetcher (gray metal arm), and the thread bread (copper piece with the little velcro piece at the end). Viking has upgraded a couple of these pieces from the original versions, so you should have better cutting results. And of course clean out this area while your at it.
Apr 28, 2011 | Husqvarna Designer I
My machine is Model #981668. My whole bobbin case
My husband put it together. It's been a while since I used it.
Thank you anyway.
Oct 07, 2009 | Necchi Sewing Machines
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Bobbin Thread cutter no longer works
I have a designer SE, I ran across this site and found it very helpful. This person is a retired machine repair person and has a wealth of knowlege. <http://www.sewmuch4retirement.com/tips.html> from what I understand the blade needs to be cleaned as part of the Maintenance, it also can be replaced.
Take a look at this site, perhaps it will help
Far Away Grandma
Aug 15, 2008 | Husqvarna Designer I
Sewing Machines Logo
222 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
