Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Snow building up around ice maker opening
I have a two-door GE (side freezer) three years old. For one month now snow is accumulating around the opening of the ice maker. It also falls in my glass when ice cubes drop. I tried different setting and it is the same.
Thanks for you help.
Nicole
  • 30 Answers
Check to make sure the dispenser door is closing all the way and I mean ALL the way.
GE has had issues with the solenoid rusting out on those units and not letting the door close all the way.
Posted on Sep 04, 2009
Side by side refrigerator will not cool and ice maker does not work although the freezer is cooling. It is 5 years old.
check damper operations. blockage of air flow. check make sure no ice build up in back panel of freezer side like a snow pattern
Feb 07, 2010 | Refrigerators
Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
Excessive frost buildup in bottom freezer section of Kenmore refr
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. if this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that can occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of your ice maker causing this are very, very slim...in 35 years in the industry ..I have never had an ice maker cause frost due to water spray...it will almost always result solid sheets of Ice..if it evers does cause a spray....which like I said is rare...lottery ticket type rare :-)
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Mar 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Noise on the ice maker
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Jan 05, 2009 | Samsung RS2630WW Side by Side Refrigerator
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Whirlpool Side by Side Ice Maker Not Making Ice
sometimes if you use the water filer too long and don't change, can cause this problem.
Jul 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Slow buildup of ice in freezer
The hissing is normal. It was in defrost.
The frost may be caused by a bad seal around freezer door. Check to be sure seal is hitting properly all around door. Also be sure door is getting closed properly.
Nov 08, 2007 | LG LFC25760 French Door Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
174 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
