Question about Vacuums
My Miele vacuum full bag indicator
It doesn't seem like I'm getting much use out of my vacuum bags, and they're quite expensive. Of course, if I want to lower the suction power to 500-750, then the indicator isn't fully "red," but I've also lost suction power. I have a navy blue carpet, and it shows every speck of lint, so I need the power at 900 to 1100 or I'll be vacuuming over the same spot a dozen times to get everything up. Is there something else I can do to make the suction power high and the bag last longer? Is this something to do with a filter I'm not seeing or that needs changing?
    President:
  • 1,673 Answers
Check the suction at the vac, without the hose, if it is strong, then you hose is clogged. If it is weak, filters could be the problem, one is the back where the bag sits, the other is on the top, you can see it when you raise the lid.
Posted on Jan 29, 2008
  • 694 Answers
For a longer lasting bag, try vacuuming up 4-6 sheets of toilet paper. This provides more surface area for the dust to cling to. It may not work on all brands/models, but on many it does.
Posted on Sep 30, 2009
I just replaced the bag (used recommended Miele bag). When I turned on the machine the red "bag full" indicator comes on and the suction seems poor. I tried reinserting bag. ?
Good afternoon Kristen.
Vacuum cleaners usually pop the 'bag full' indicator when they lose suction due to the load of dirt in the bag impeding the motor pulling air through.
If you are still getting the indicator with a new bag, and already did the prudent re-seating of the bag, the next thing is likely a clog or blockage elsewhere in the vacuum. You don't specify the model, so I can't be too specific.
Safety first. Please please please make sure the unit is unplugged before you start disassembling.
As you are able, detach hoses, look in the back of the brush unit, see if there's a blockage. Wads of crumpled paper are particularly good at wedging themselves into corrugated flex lines. Depending on location, I've found that a wire coat hanger, bent into marshmallow-roaster configuration, with the old hook bent with some pliers into a long straight section with a small half-loop at the end, can be a good probe for the long sections of tube to see if it runs into anything, and then perhaps hook it and pull it out. Be careful if you do this to not hook the tubing walls and tear them.
Hoping this helps!
D
Nov 18, 2015 | Miele Vacuums
How do you read the "full bag indicator" on a Meile S7260?
typically if your vacuum is loosing performance it is time to replace the bag depends on how fine of dust some really fine dust will clog the pores at a 1/4 full
Apr 14, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
The bag on my s7210 doesn't seem to fit properly and I am getting dust in the bag compartment instead of teh bag - what am I doing wrong?
Check to see that the bag mounting bracket and torsion spring are in place, the bracket will be either a dark graphite color like most of the vacuum or green. If you only have a protruding tube where you put the bag on, then your bag mount have come off and you should order a new one; very inexpensive and it comes with a new spring.
Oct 17, 2011 | Miele S7210 Bagged Upright Vacuum
Using hoover, stopped working. Bag very full so changed. Hoover seems very hot. Will not work. Checked fuse
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Apr 04, 2011 | Miele Cat & Dog 326i Bagged Canister...
I have the Miele cat & dog S5000 vacuum. I have had it about 1 year and lately the suction doesn't seem as strong and the full bag indicater is always full. I have followed instructions in manual but...
Greetings,
I would say that you have a slight clog in the hose or in the power nozzle somewhere. The full bag indicator is just a guage that will indicate full when it feels like it's lost suction. Example: If you were to take the hose and cover it with your hand, you'll notice that bag full indicator will show full.
To check and see where the clog in the vacuum is, remove the wands and floor attachment so you just have the hose on the vacuum cleaner. With just the hose attached, turn the vacuum cleaner on. Does it still show a full bag? If yes, then remove the hose completely from the vacuum cleaner so it's just the canister part by itself and turn on the vacuum again. If the bag full indicator is now showing an empty bag, this means that you have a clog in your hose.
If the bag full indicator displayed an empty bag when you had the hose on the vacuum, but shows a full bag when you have the wands and floor tool attached, this means that you have a clog in the vacuum either in the wands, or the floor attachment.
For removing clogs from the hose, the quickest way is to just purchase a plumbers snake at your local hardware store, and run the snake through the hose until you find the clog. You may also take a high pressure hose and spray it down the hose until the clog is cleared, but if you use a water hose, MAKE SURE the hose is 100% dry before you use it again.
Also that bag full indicator can be adjusted if you are getting a lot of suction power and it still shows full.
I hope that these suggestions helped you diagnosis your Miele canister to figure out why the indicator showed full. If this helped you please rate my repair helpful.
Feel free to contact me if you need further assitance, I'm always happy to help.
Chris J.
Mar 13, 2010 | Vacuums
My Miele bags for S241 vacuum cleaner have just been replaced by the new HyClean bag. There are less in the box and you can't empty them either - a mesh of cords being in the way. I knoe you're not...
The old style bags are not available any longer. The new HyClean bags have a larger capacity then the original style. You get the same amount of capacity out a box of the new bags as you did the box of the old. I know they are still expensive. I would recommend calling an internet company and trying to buy a quantity of bags at a time to see if you can get a little better price.
Sep 28, 2009 | Miele S4210 Sirius Bagged Canister Vacuum
Mine is a new upright Meile power plus. When I have it
Sounds like you have a clog. There are screws in the back of the vacuum that you can undo and find the clog. If you need assistance or if that doesn't solve the problem.
http://miele.com/locator/locator_new.asp?nav=800&snav=800&tnav=800&oT=7
^this will help you find an authorized Miele repairshop.. you can also call them at (888) 785-2828
Aug 31, 2009 | Miele Powerhouse Plus Bagged Upright...
When turned on the sound is like its screaming. It appears to be coming from the filter compartment. It all seems to work ok.Thanks
I suggest checking the filter. If it's coming from the HEPA filter area, the filter might be out of position or possibly you have the wrong kind of filter. Miele uses 2 different types of HEPA filter so that could be the problem.
Aug 23, 2009 | Miele Cat Dog Plus S511 Bagged Canister...
Stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
979 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
